11
I am on an Ubuntu 16.04.1 LTS system. I use udisksctl command to mount and unmount my USB flash drive, but I sometimes eject it in nautilus. I can see the device in Disks utility even after ejecting.
I searched the site and found the question How do I mount ejected external USB flash Via terminal, but I could not find an answer to mount an ejected USB drive in the answers of that question.
Can you please explain to me how to mount an ejected USB drive without unplugging it?
Eliah Kagan
  • 119,640
The following will eject the USB device.
sudo eject /dev/sde
The following will mount the USB device without unplugging it.
sudo eject -t /dev/sde
Reference: http://www.upubuntu.com/2011/09/how-to-remount-usb-stick-without.html
Check your usb flash name with:
lsusb
my sandisk example:
Bus 003 Device 005: ID 0781:540e SanDisk Corp. Cruzer Contour Flash Drive
Now i know my sandisk is on bus 003 and device 005
Then you have to check your usb bus and port number with:
lsusb -t
Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/14p, 480M
|__ Port 5: Dev 5, If 0, Class=Mass Storage, Driver=usb-storage, 480M
Now i know that bus 3 device 5 is on port 5 so we can go to :
/sys/bus/usb/drivers/usb
and disable port:
sudo tee unbind <<< "3-5"
or enable port:
sudo tee bind <<< "3-5"
EdiD
  • 4,617
  • 27
  • 41
When I inserted my usb drive I got this:
ls /dev/sdd*
/dev/sdd /dev/sdd1
I then ejected it
sudo eject /dev/sdd
ls /dev/sdd*
/dev/sdd
I then unejected it as per this answer
sudo eject -t /dev/sdd
ls /dev/sdd*
/dev/sdd /dev/sdd1
You might want to check the disk by using fdisk
sudo fdisk /dev/sdd -l
philn
  • 163
