After safely remove or eject it, i want to remount it without unplug it, and re-plug it again .. so Any suggestion pls?
PS
after using eject all usb memories are out of fdisk command scope i don't think it is that easy
` Device Boot Start End Blocks Id System
/dev/sda1 109473792 1953525167 922025688 83 Linux
/dev/sda3 2050048 99706297 48828125 83 Linux
/dev/sda4 99708926 109471743 4881409 5 Extended
Partition 4 does not start on physical sector boundary.
/dev/sda5 99708928 109471743 4881408 82 Linux swap / Solaris
Partition table entries are not in disk order`
None of them is the usb memory
