35
I want to try C++17 features and I want to install standard compliant compiler (preferably GCC). I'm totally new to Linux and Ubuntu and I simply don't understand a lot.
I tried to follow https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test but with no luck. First I ran:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
As I understood this command installs some keys. Next I tried:
sudo add-apt-repository ppa:ubuntu-toolchain-r/gcc-7
That returned:
Error: 'ppa:ubuntu-toolchain-r/gcc-7' invalid
Next I tried to install clang development branch:
apt-get install clang-4.0 lldb-4.0
And it gives me
E: Unable to locate package clang-4.0
E: Couldn't find any package by glob 'clang-4.0'
E: Couldn't find any package by regex 'clang-4.0'
E: Unable to locate package lldb-4.0
E: Couldn't find any package by glob 'lldb-4.0'
E: Couldn't find any package by regex 'lldb-4.0'
What does all this means? What's wrong?
Eliah Kagan
  • 119,640
nikitablack
  • 545
Super mega GCC table for all Ubuntu versions: How do I use the latest GCC on Ubuntu?
Ubuntu 16.04 and below
There is an official Ubuntu GCC test PPA which should be preferred:
sudo apt-get update
sudo apt-get install gcc-7 g++-7
gcc-7 --version
GCC 7 was release in May 2017, so too late for 17.04 main release.
The PPA does not currently have GCC for newer releases e.g. 16.10, only LTS 12.04, 14.04 and 16.04, as can be seen at: https://launchpad.net/~ubuntu-toolchain-r/+archive/ubuntu/test | snapshot. I think it had 17.04 previously but it was removed? See also: https://unix.stackexchange.com/questions/371737/install-gcc-7-on-ubuntu
Tested on Ubuntu 16.04, October 2018.
Ubuntu 17.10 and above
Has GCC 7.2 and clang 4 by default! https://packages.ubuntu.com/artful/gcc | https://packages.ubuntu.com/artful/clang
$ gcc --version
gcc (Ubuntu 7.2.0-8ubuntu3) 7.2.0
$ clang --version
clang version 4.0.1-6 (tags/RELEASE_401/final)
GCC 8 on 16.04
sudo apt-get update
sudo apt-get install gcc-8 g++-8
gcc-8 --version
gives 8.1.0 as of 2018-11.
Default in Ubuntu 18.04:
Crosstool-NG
If you are really serious about this, compile and use your own GCC with Crosstool-NG as explained at: https://stackoverflow.com/questions/847179/multiple-glibc-libraries-on-a-single-host/52454603#52454603
This will allow you to use a wide variety of GCC versions on a wide variety of Ubuntu versions without downloading blobs from PPAs you don't necessarily trust.
26
You can already install gcc-7 and g++-7 from this package.
sudo add-apt-repository ppa:jonathonf/gcc-7.1
sudo apt-get update
Jendas
  • 788
OP asks for "how to install...". Alternatively, how to compile Clang 4.0.
You may compile from the source code using the script from Microsoft ChakraCore's GitHub repository.
wget https://raw.githubusercontent.com/Microsoft/ChakraCore/master/tools/compile_clang.sh
Update LLVM_VERSION="3.9.1" at line 7 to LLVM_VERSION="4.0.0"
sudo ./compile_clang.sh
It will download and compile Clang 4.0 (and whole compiler toolchain) with LLVM Gold support.
muru
  • 207,228
Here my step to install gcc-7/g++-7 on Ubuntu 16.04 LTS AND make it the default.
First to install gcc-7/g++-7 using the official ppa.
sudo apt update -qq
sudo apt install -yq software-properties-common
sudo add-apt-repository -y ppa:ubuntu-toolchain-r/test
sudo apt update -qq
sudo apt install -yq g++-7
with:
  • -y: auto confirm
  • -q: quiet mode (several increase the quiet level)
Then make it the default alternative
sudo update-alternatives \
 --install /usr/bin/gcc gcc /usr/bin/gcc-7 60 \
 --slave /usr/bin/g++ g++ /usr/bin/g++-7 \
 --slave /usr/bin/gcov gcov /usr/bin/gcov-7 \
 --slave /usr/bin/gcov-tool gcov-tool /usr/bin/gcov-tool-7 \
 --slave /usr/bin/gcc-ar gcc-ar /usr/bin/gcc-ar-7 \
 --slave /usr/bin/gcc-nm gcc-nm /usr/bin/gcc-nm-7 \
 --slave /usr/bin/gcc-ranlib gcc-ranlib /usr/bin/gcc-ranlib-7
now running gcc --version should return gcc 7.4.0 IIRC
Mizux
  • 101
