I recently migrated from Windows to Ubuntu (actually Codeanywhere running Ubuntu) and need to upgrade to gcc 7, as it comes with gcc 4.8.2, and I need C ++ 17. I executed the following commands on the terminal:
$ sudo apt-get install software-properties-common python-software-properties
$ sudo add-apt-repository ppa:jonathonf/gcc-7.1
$ sudo apt-get update
$ sudo apt-get install gcc-7 g++-7
But I received the following error:
g++-7 : Depends: libisl15 (>= 0.15) but it is not installable
Depends: libmpfr4 (>= 3.1.3) but 3.1.2-1 is to be installed
gcc-7 : Depends: cpp-7 (= 7.1 .8-10ubuntu1~14.04.york8) but it is not going to be installed
Depends: binutils (>= 2.26.1) but 2.24-5ubuntu14.2 is to be installed
E: Unable to correct problems, you haye held broken packages.
Ubuntu version:
$ cat /etc/lsb*
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.5 LTS"
What I need to do?
Sorry for my English.
EDIT
Missing package islibisl15 (>= 0.15), and not libisllS (>= 8.15). Sorry.
