I used this command
echo $(dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p') $(dpkg --list | grep linux-headers | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p') | xargs sudo apt-get -y purge
from this link to remove old kernels to free up the disk space, but while executing that command I get the following message
1 upgraded, 2 newly installed, 2 to remove and 288 not upgraded.
Need to get 52.0 MB of archives.
After this operation, 186 kB of additional disk space will be used.
Shouldn't this command free up the disk space instead of using additional disk space ?
Didn't you do:
echo $(dpkg --list | grep linux-image | awk '{ print $2 }' | sort -V | sed -n '/'`uname -r`'/q;p') $(dpkg --list | grep linux-headers | awk '{ print $2 }' | sort -V | sed -n '/'"$(uname -r | sed "s/\([0-9.-]*\)-\([^0-9]\+\)/\1/")"'/q;p') | xargs echo sudo apt-get -y purge
first?
Seriously, use the /usr/bin/purge-old-kernels script (part of the byobu package)
waltinator
  • 37,856
Try this:
Open a terminal,
Press Ctrl+Alt+T
Run it:
exec sudo -i
CONFOLD=$(dpkg -l|grep "^rc"|awk '{print $2}')
KERNELCUR=$(uname -r|sed 's/-*[a-z]//g'|sed 's/-386//g')
PKGLINUX="linux-(image|headers|ubuntu-modules|restricted-modules)"
PKGMETALINUX="linux-(image|headers|restricted-modules)-(generic|i386|server|common|rt|xen)"
KERNELSOLD=$(dpkg -l|awk '{print $2}'|grep -E $PKGLINUX |grep -vE $PKGMETALINUX|grep -v $KERNELCUR)
apt-get purge $CONFOLD
apt-get purge $KERNELSOLD
apt-get autoremove
To free up more disk space you can continue running:
apt-get install --reinstall deborphan
deborphan
apt-get --purge remove $(deborphan)
deborphan --libdevel
apt-get --purge remove $(deborphan --libdevel)
deborphan --find-config
dpkg --purge $(deborphan --find-config)
apt-get autoremove
apt-get clean
kyodake
  • 17,808
