21
I've seen plenty of questions regarding this, but they all seem to do a remap of the keys, instead of an actual macOS behavior.
My main use case would be to "split" the shortcuts: for example I would like to have Super+C to copy text, and Ctrl+C to send a SIGINT to the current program.
In this case, a simple remap or swap of Super and Ctrl would not work.
I find the behavior of the mac to be very practical, because all the most common shortcuts use Super, and the famous copy shortcut doesn't overlap the famous SIGINT shortcut.
Most terminal apps react to Ctrl-* shortcuts, and they mostly overlap with "standard" shortcuts. In GNOME Terminal, we have to press Ctrl+Shift+C to copy text, whereas in other applications like Firefox, Ctrl+C is used. This is quite cumbersome and inconsistent compared to Super+C.
Tim
  • 33,500
Ubuntu 20.04, June 2020
After spending an insane amount of time trying to figure out how to get MacOS-like shortcuts working on Ubuntu, I've found kinto. Just follow the instructions, it worked perfectly on 20.04 for me using an Apple aluminum keyboard. CMD-C/V copies & pastes everywhere and CTRL-C etc. work in the terminal.
vfxdev
  • 186
-1
You can achieve using xmodmap commands:
remove mod4 = Super_L
keysym Super_L = Control_L
add Control = Control_L
Save the above lines as super_as_ctrl.xmodmap. Test by executing
xmodmap super_as_ctrl.xmodmap
To make the change permanent (surviving re-login/reboot) just rename the file to .Xmodmap in your home folder.
(Tested on Ubuntu 14.x)
PS: You could also make use of other windows button. Not sure how to do that.
Abhinandan
  • 59
To create new shortcut and delete old ones, Simply go to system settings >> keyboard >> shortcuts. There you can see all the shortcuts, edit it, delete it and create new ones.
muru
  • 207,228
-1
The following lives in my $HOME/.uxSwapCapsLock-and-Ctrl. It effectively swaps the functionality of the CapsLock and Ctrl keys for any shell in use on any Linux system whenever I log in, and initiate an interactive session within a shell, on a given system. I'm sure you can learn about the pertinent key name that you are trying to modify, and are referred to by xmodmap, in order to get the functionality you want. This code gets initiated every time I login and have an interactive session via .profile, but it lives in a .ps1 file for this purpose.
#!bin/bash
xmodmap -e "remove Lock = Caps_Lock"
xmodmap -e "remove Control = Control_L"
xmodmap -e "keysym Control_L = Caps_Lock"
xmodmap -e "keysym Caps_Lock = Control_L"
xmodmap -e "add Lock = Caps_Lock"
xmodmap -e "add Control = Control_L"
#End script
This is the .profile check in order to make the swap take place:
if [ -f  "$HOME/.uxSwapCapsLock-and-Ctrl" ]; then
   .  $HOME/.uxSwapCapsLock-and-Ctrl
fi
muru
  • 207,228
