I would like to record audio while Audacity is running in the background, e.g. because I am focused on another window. Is it possible to control the start and stop of a recording using global keyboard shortcuts?
Zanna
  • 72,312
orschiro
  • 13,687
Does Audacity have cli options?
Unfortunately, looking into man audacity, does not show any interesting or relevant options:
OPTIONS
       -help     display a brief list of command line options
       -version  display the audacity version number
       -test     run  self  diagnostics  tests  (only  present  in development
                 builds)
       -blocksize nnn
                 set the audacity block size for writing files to disk to  nnn
                 bytes
However...
simply pausing/continuing Audacity from cli works exactly similarly to pausing/continuing recording
I tested pausing Audacity as a process, with the commands kill -stop <pid> and kill -cont <pid>. It did the job perfectly; it stopped recording immediately, resuming immediately when the process was continued. Even after 6 or seven hours, it stops/resumes recording right away with these commands.
Adding the two commands to shortcut keys does exactly what you describe.
How to use
Add the following two commands to shortcut keys:
/bin/bash -c "kill -stop $(pgrep audacity)"
...to stop (pause) recording, and
/bin/bash -c "kill -cont $(pgrep audacity)"
...to resume, and you have your own shortcut keys to start/stop (actually pause) recording.
Only the initial starting of the recording needs to be done via the Audacity GUI.
Adding to shortcut keys
Choose: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add the two commands above to two different shortcut keys.
Extending options
Of course we can extend options, e.g.
/bin/bash -c "kill -cont $(pgrep audacity) && notify-send Recording"
and
/bin/bash -c "kill -stop $(pgrep audacity) && notify-send Stopped"
...to show a notification on the current state, or even make a panel icon to show the current state. Anything is possible
Additionally, a toggle script, as requested in a comment
The script below will toggle recording. Add it to either a shortcut key or launch it in any other way.
The script reads the current process state from the file /proc/<pid>/status, and decides what the targeted state should therefore be.
Additionally, the script notifies the user what happens in a notification (using notify-send).
#!/usr/bin/env python3
import subprocess
try:
    pid = subprocess.check_output(["pgrep", "audacity"]).decode("utf-8").strip()
except subprocess.CalledProcessError:
    pass
else:
    state = "(stopped)" in open("/proc/"+pid+"/status").read()
    if state == True:
        cmd = ["kill", "-cont", pid]; msg = "Recording"
    else:
        cmd = ["kill", "-stop", pid]; msg = "Pausing"
    subprocess.Popen(cmd)
    subprocess.Popen(["notify-send", msg])
To use it
  • Simply copy it into an empty file, save it as toggle_record.py
  • Test run it with the command:
    python3 /path/to/toggle_record.py
  • If all works fine add it to a shortcut key as explained earlier in the answer.
Jacob Vlijm
  • 85,475
Can Audacity be controlled when its window not in focus ?
In theory, yes, since it has a scripting module, which apparently can be used with Perl scripting language, but as of right now I've not seen one made, so there is potential for Perl-skilled developers to write one.
But as it is, the answer to your question is "no".
arecord Script
What's great about open source community is that there's always an alternative. In this case, arecord , which works from command-line. What you see below is a very quick script I've made, which is intended to be bound to a keyboard shortcut. Usage is simple: press key combination - recording starts, and press it again to stop recording.
What's "hard-coded" in this script is the default wav type of recording and ~/Music/records folder. Users are free to edit this script as they like to use their own options/filetypes/locations, etc. Please consult arecord man page for additional options.
Eventually I plan rewriting this script in Python, which will allow more fine-grained control of user's directories, add command-line options, perhaps other things. As for now, this does 75% of the job needs to be done.
Below is the source code of the script which is also available on my GitHub repository. Standard rules for creating and using scripts apply: ensure it has executable permissions and is stored in your ~/bin folder
#!/bin/bash
# Author: Serg Kolo
# Date: Dec 1, 2016
# Purpose: simple script for recording audio with arecord
# Written for: https://askubuntu.com/q/855893/295286
record_audio()
    # Set up some variables to control arecord here
    # Please remember to quote the variables
    # and pay attention to slashes in file paths
    filetype="wav"
    filename="record_$(date +%H_%M_%m_%d_%Y)"
    directory="$HOME/Music/recordings/"
    if ! [ -d "$directory" ];
    then
        mkdir "$directory"
    fi
    # This part will initiate recording of timestamped
    # please see arecord's man page for other options
    notify-send "Recording started"
    exec arecord -t "$filetype" "$directory""$filename"."$filetype"
main()
    if pgrep -f "arecord" ;
    then
       pkill -f "arecord" && notify-send "Recording stopped"
    else
       record_audio
    fi
main "$@"
additional information:
Yes. You can use a combination of a script, xdotool, wmctrl and Ubuntu's hotkey.
First create the file to select the recording window and send the command key to that window.
Then assign a hotkey to activate the script.
The Script
#!/bin/bash
Specify the Window running your recording by running
"./hkrecord.sh getwindowid" from the command line.
Alternatively you can edit the ~/recordfile and place your own string. This
first line of the fie will be used
Ensure you have the following "xdotool" and "wmctrl" installed.
recordfile="$HOME/recordfile"
getwindowid(){ windowid=$(wmctrl -lp | awk '{$2=$3=$4=":"; print $0}'| awk -F:
'{print $1"\n"$4}' | zenity --list --column="No" --height=800 --width=1000
--column="Select your choice"
--text="Text above column(s)" --hide-column=1 --title="My menu" 2>/dev/null) [[ "$windowid" ]] && sed -i "1i @$windowid" $recordfile ||
echo "No Window selected" exit }
if [ ! $# -eq 0 ]; then if [[ "x$1" == "get" ]]; then
echo "Getting the window id" getwindowid exit fi fi
recordwindow="$(head -n1 $recordfile)"
if [ "$(echo $recordwindow | egrep '@0x')" ]; then windowid=$(echo $recordwindow | sed "s/@//") else windowid=$(echo $(wmctrl -lp|egrep -i $recordwindow)|head -n1|
awk '{print $1}') echo "$windowid|$recordfwindow" # debug line... can be commented out. fi
echo "Using WindowID: $windowid" # debug line... can be commented out.
if [ -z $windowid ]; then espeak "Can't locate specified window!" espeak "Exiting..." exit fi
xdotool key --window $windowid p
Save the script to a convenient area such as /usr/local/bin/hkrecord.sh
Assign the hotkey
First run the script from the commandline as a quick test. Then assign the global keyboard shortcut. To specify the window (needed only one time) run:
$ ./hkrecord.sh getwindow
Running hkrecord.sh without an argument will control the recording.
Go into System Settings -> keyboard and add a custom Keyboard Shortcut. Pick a hotkey that won't conflict with your foreground program. I use Shift+Ctrl+P.
This is the configuraton for the Custom Shortcut:
Command:     /usr/local/bin/hkrecord.sh
I placed the instructions as comments in the script file.
As an added benefit, the same Global Hotkey can be used for pausing playback. I use this system as a dictaphone to write from my recorded notes.
I tried to make the script very simple to be easy to understand and customize. Thoroughly tested, it will work seamlessly.
Note: Thanks goes out to don_crissti and and George_Vasiliou (https://unix.stackexchange.com/a/328548/81664) for helping me with the GUI for selecting the record window.
L. D. James
  • 25,444
