This post relates to this other question of mine: Recovering Data
I'm finding a partition on TestDisk, but it's about 300 GB and I don't have an external hard drive on hand.
  • Is it possible to put pieces of the recovered data on a 16 GB flash drive, then bring it over to my other laptop? (The laptop has a terabyte hard drive so storage is not an issue)
    Or is there anything else I can do, such as uploading the recovery to the cloud?
Thanks!
RPT
  • 29
There are many options but It too broad to pass or expend all of them. Our refrence here is this simple recover method explained in:
Recovering broken or deleted NTFS partitions
It is always recommended to make dd or ddrescue image of the partition, then run testdisk/photorec through the image. Which means 02x 300GB free space is needed.
  • Both dd/ddrescue support start position and size. So you can read chunks one by one, copy to flash disk then merge them on PC2.
    man dd
       count_bytes
              treat 'count=N' as a byte count (iflag only)
       skip_bytes
              treat 'skip=N' as a byte count (iflag only)
       seek_bytes
              treat 'seek=N' as a byte count (oflag only)
    The disadvantage is that you have 20 rounds (300GB/15GB) of copy/paste each with a chunk of 15GB.
  • Setup an NFS share on PC2 and mount it on PC1, Recommended Ethernet cable connection instead of WiFi for quick transfer.
    Reference: Ubuntu Server Guide: Network File System (NFS)
    PC2: Server
    1. Install NFS server
      sudo apt-get install nfs-kernel-server
    2. Setup share folder
      sudo nano /etc/exports
      /media/<username>/<partition-name>/<shared-folder>    *(rw,sync,no_root_squash)
    3. Start the NFS service
      sudo service nfs-kernel-server start
    PC1: Client
    1. Install NSF client tools
      sudo apt-get install nfs-common
    2. Mount the shared folder
      sudo mkdir /mnt/pc2-nfs
      sudo chown <username> <username> /mnt/pc2-nfs
      sudo mount <pc2-ip>:/media/<username>/<partition-name>/<shared-folder>  /mnt/pc2-nfs
user.dz
  • 49,176
