I am getting an error when i try to pip install Django or anything, say..
pip install Django throws an error:
Traceback (most recent call last): File "/usr/local/bin/pip", line
11, in <module>
sys.exit(main()) File "/usr/local/lib/python2.7/dist-packages/pip/__init__.py", line 233, in
main
return command.main(cmd_args) File "/usr/local/lib/python2.7/dist-packages/pip/basecommand.py", line 251,
in main
timeout=min(5, options.timeout)) as session: File "/usr/local/lib/python2.7/dist-packages/pip/basecommand.py", line 72,
in _build_session
insecure_hosts=options.trusted_hosts, File "/usr/local/lib/python2.7/dist-packages/pip/download.py", line 329, in
__init__
self.headers["User-Agent"] = user_agent() File "/usr/local/lib/python2.7/dist-packages/pip/download.py", line 93, in
user_agent
from pip._vendor import distro File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/distro.py", line
1050, in <module>
_distro = LinuxDistribution() File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/distro.py", line
594, in __init__
if include_lsb else {} File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/distro.py", line
933, in _get_lsb_release_info
raise subprocess.CalledProcessError(code, cmd, stdout) subprocess.CalledProcessError: Command 'lsb_release -a' returned
non-zero exit status 1
Then I checked lsb_release -a in my system. it is also corrupted, throwwing an error:
File "/usr/bin/lsb_release", line 64
print("No LSB modules are available.", file=sys.stderr)
^ SyntaxError: invalid syntax
Where could be the problem and how can I solve this?
