I have a VM with: OS: Ubuntu 16.04.1 LTS Kernel: Linux 4.4.0-59-generic Architecture: x86-64
In this system, there were 2 versions of python: 2.7.12 and 3.5. Pip was also installed. Pip version is:
pip 9.0.1 from /usr/local/lib/python2.7/dist-packages (python 2.7)
Every time pip install <package> was run, I got error. The main error was because lsb_release -a returned error. I ran lsb_release -a from console and I got invalid syntax error:
File "/usr/bin/lsb_release", line 64
print("No LSB modules are available.", file=sys.stderr)
The header of lsb_release file has the following:
#!/usr/bin/python3 -Es
But the system does not seem to know how to get to python3, even though the symbolic link was set for python3 to python3.5, using the following command:
sudo ln -s /usr/bin/python3.5 /usr/bin/python3
The output of command ls -l /usr/bin/python* is the following:
lrwxrwxrwx 1 root root 9 Dec 9 2015 /usr/bin/python -> python2.7
lrwxrwxrwx 1 root root 9 Dec 9 2015 /usr/bin/python2 -> python2.7
-rwxr-xr-x 1 root root 3546104 Nov 19 01:35 /usr/bin/python2.7
lrwxrwxrwx 1 root root 33 Nov 19 01:35 /usr/bin/python2.7-config -> x86_64-linux-gnu-python2.7-config
lrwxrwxrwx 1 root root 16 Dec 9 2015 /usr/bin/python2-config -> python2.7-config
lrwxrwxrwx 1 root root 9 Jan 26 09:07 /usr/bin/python3 -> python3.5
-rwxr-xr-x 2 root root 3546104 Jan 19 14:23 /usr/bin/python3.5
lrwxrwxrwx 1 root root 33 Nov 17 11:23 /usr/bin/python3.5-config -> x86_64-linux-gnu-python3.5-config
-rwxr-xr-x 2 root root 3546104 Jan 19 14:23 /usr/bin/python3.5m
lrwxrwxrwx 1 root root 34 Nov 17 11:23 /usr/bin/python3.5m-config -> x86_64-linux-gnu-python3.5m-config
lrwxrwxrwx 1 root root 16 Mar 23 2016 /usr/bin/python3-config -> python3.5-config
lrwxrwxrwx 1 root root 10 Jun 6 2016 /usr/bin/python3m -> python3.5m
lrwxrwxrwx 1 root root 17 Mar 23 2016 /usr/bin/python3m-config -> python3.5m-config
lrwxrwxrwx 1 root root 16 Dec 9 2015 /usr/bin/python-config -> python2.7-config
Checking the version of python3.5, I got back the version of 2.7:
$ /usr/bin/python3.5 --version
Python 2.7.12
Something does not look right from my system, when I execute
ll -a /usr/share/man/man1 | grep python. The output is:
-rw-r--r-- 1 root root 3367 Dec 9 2015 dh_python2.1.gz
-rw-r--r-- 1 root root 3280 May 18 2016 dh_python3.1.gz
lrwxrwxrwx 1 root root 14 Dec 9 2015 python.1.gz -> python2.7.1.gz
lrwxrwxrwx 1 root root 14 Dec 9 2015 python2.1.gz -> python2.7.1.gz
-rw-r--r-- 1 root root 5640 Nov 19 01:32 python2.7.1.gz
lrwxrwxrwx 1 root root 38 Nov 19 01:35 python2.7-config.1.gz -> x86_64-linux-gnu-python2.7-config.1.gz
lrwxrwxrwx 1 root root 21 Dec 9 2015 python2-config.1.gz -> python2.7-config.1.gz
lrwxrwxrwx 1 root root 14 Jun 6 2016 python3.1.gz -> python3.5.1.gz
-rw-r--r-- 1 root root 5174 Nov 17 10:43 python3.5.1.gz
lrwxrwxrwx 1 root root 38 Nov 17 11:23 python3.5-config.1.gz -> x86_64-linux-gnu-python3.5-config.1.gz
lrwxrwxrwx 1 root root 14 Nov 17 11:23 python3.5m.1.gz -> python3.5.1.gz
lrwxrwxrwx 1 root root 39 Nov 17 11:23 python3.5m-config.1.gz -> x86_64-linux-gnu-python3.5m-config.1.gz
lrwxrwxrwx 1 root root 21 Mar 23 2016 python3-config.1.gz -> python3.5-config.1.gz
lrwxrwxrwx 1 root root 15 Jun 6 2016 python3m.1.gz -> python3.5m.1.gz
lrwxrwxrwx 1 root root 22 Mar 23 2016 python3m-config.1.gz -> python3.5m-config.1.gz
lrwxrwxrwx 1 root root 21 Dec 9 2015 python-config.1.gz -> python2.7-config.1.gz
-rw-r--r-- 1 root root 921 Nov 19 00:15 x86_64-linux-gnu-python2.7-config.1.gz
lrwxrwxrwx 1 root root 39 Nov 17 11:23 x86_64-linux-gnu-python3.5-config.1.gz -> x86_64-linux-gnu-python3.5m-config.1.gz
-rw-r--r-- 1 root root 907 Nov 23 2013 x86_64-linux-gnu-python3.5m-config.1.gz
lrwxrwxrwx 1 root root 38 Mar 23 2016 x86_64-linux-gnu-python3-config.1.gz -> x86_64-linux-gnu-python3.5-config.1.gz
lrwxrwxrwx 1 root root 39 Mar 23 2016 x86_64-linux-gnu-python3m-config.1.gz -> x86_64-linux-gnu-python3.5m-config.1.gz
lrwxrwxrwx 1 root root 38 Dec 9 2015 x86_64-linux-gnu-python-config.1.gz -> x86_64-linux-gnu-python2.7-config.1.gz
The 3.5 package, x86_64-linux-gnu-python3.5-config.1.gz, has a symbolic link to 3.5m. Is it odd?
The problem now is how to correct the python3 point to the correct version. Is there a way to do so?
Thank you
