10
I want to run a command before and after every single command that gets executed in a terminal (i.e. clear before and then reset). I want this to happen automatically and not with a short alias or similar.
I have looked into bashrc and /usr/share/bash-completion/bash_completion although the latter seems to be just for the auto completion feature with the Tab?
Where should I make my changes?
Katu
  • 3,663
In your .bashrc:
function process_command() {
  ... do something with $BASH_COMMAND ...
trap process_command DEBUG
For a good example see "Make gnome-terminal show the command running as title" on AskUbuntu.
To solve the original poster's request to run clear before the command and reset after the command, add to .bashrc:
function before_command() {
  case "$BASH_COMMAND" in
        $PROMPT_COMMAND)
          clear;
  esac
function before_prompt() { reset ; }
trap before_command DEBUG
PROMPT_COMMAND=before_prompt
In man bash look for PROMPT_COMMAND and trap .-lp.
AlexP
  • 10,435
