I want the name of command running , e.g unzip to be visible through the title bar of gnome-terminal , but it seems to be impossible , if the application running doesn't set a title explicitly , even though I choose 'Replace initial title' option in the profile dialog.
This has been sort of answered here.
trap 'command' DEBUGmakes bash runcommandbefore every command.echo -ne "\033]0;Title\007"changes the title to "Title"$BASH_COMMANDcontains the command being run.
Combining these we get
trap 'echo -ne "\033]0;$BASH_COMMAND\007" > /dev/stderr' DEBUG
Then we just have to reset the title after we complete the command. I did this by setting $PS1 to change the title to the current path.
tl;dr: Add these two lines (in this order, otherwise I got a garbled prompt) to the bottom of ~/.bashrc
PS1="\033]0;\w\007${PS1}"
Edit: Your $PS1 might already change the title, in which case only the last line is needed.
This is a more complete solution actually taking care of bash-completion spamming garbage.
To be clear: I did nothing on my own here but research. All credit goes to Marius Gedminas.
This works perfectly for me with Gnome-Terminal/Terminator (put it in your .bashrc or somewhere that's getting sourced)
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME}: ${PWD}\007"'
# Show the currently running command in the terminal title:
# http://www.davidpashley.com/articles/xterm-titles-with-bash.html
show_command_in_title_bar()
case "$BASH_COMMAND" in
*\033]0*)
# The command is trying to set the title bar as well;
# this is most likely the execution of $PROMPT_COMMAND.
# In any case nested escapes confuse the terminal, so don't
# output them.
echo -ne "\033]0;${USER}@${HOSTNAME}: ${BASH_COMMAND}\007"
esac
trap show_command_in_title_bar DEBUG
esac
Also this is a cross-post because I just found out about it and wanted to share and I think it's useful here as well.
