W: Target Sources (main/source/Sources) is configured multiple times in /etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list:2 and /etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list:3
W: Target Sources (main/source/Sources) is configured multiple times in /etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list:2 and /etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list:4
W: Target Sources (main/source/Sources) is configured multiple times in /etc/apt/sources.list.d/noobslab-ubuntu-apps-dependencies-xenial.list:2 and /etc/apt/sources.list.d/noobslab-ubuntu-apps-dependencies-xenial.list:3
W: GPG error: http://extras.ubuntu.com/ubuntu precise Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 16126D3A3E5C1192
W: The repository 'http://extras.ubuntu.com/ubuntu precise Release' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: http://archive.canonical.com/ubuntu/dists/precise/Release.gpg: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-security/InRelease: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-updates/InRelease: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/precise-backports/InRelease: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: http://us.archive.ubuntu.com/ubuntu/dists/precise/Release.gpg: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
W: The repository 'http://ppa.launchpad.net/webupd8team/jupiter/ubuntu oneiric Release' does not have a Release file.
W: The repository 'http://ppa.launchpad.net/folke-schwinning/personal/ubuntu xenial Release' does not have a Release file.
W: The repository 'http://ppa.launchpad.net/noobslab/apps-dependencies/ubuntu xenial Release' does not have a Release file.
E: Failed to fetch http://ppa.launchpad.net/webupd8team/jupiter/ubuntu/dists/oneiric/main/source/Sources  404  Not Found
E: Failed to fetch http://ppa.launchpad.net/folke-schwinning/personal/ubuntu/dists/xenial/main/source/Sources  404  Not Found
E: Failed to fetch http://ppa.launchpad.net/noobslab/apps-dependencies    /ubuntu/dists/xenial/main/source/Sources  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
I tried solution from this link But not getting solution
I tried to install GRASS GIS, OSGeo, etc
  1. Go inside the /etc/apt/sources.list.d and look for moka-ubuntu-daily-xenial.list and delete it if more than one entry is present.
  2. Perform the following step for noobslab-ubuntu-apps-dependencies-xenial.list as well.
  3. Where the lines are starting with E, it means error. please check whether the URL is correct or not.
  4. For all the lines with W, those are warning. According to the logs we can conclude that the URL which you have put are not reachable.
Bidyut
  • 789
  • 14
First
For the configured multiple times error, in terminal, do this:
ls -al /etc/apt/sources.list.d/moka-ubuntu-daily-xenial.list*
You'll probably see this:
Leave moka-ubuntu-daily-xenial.list alone, and delete the remaining 3 with:
sudo rm /etc/apt/source.list.d/moka-ubuntu-daily-xenial.list:2
sudo rm /etc/apt/source.list.d/moka-ubuntu-daily-xenial.list:3
sudo rm /etc/apt/source.list.d/moka-ubuntu-daily-xenial.list:4
Second
For the 404 Not Found errors, see my previous answer to this same question at how to reset update sources
Third
Ignore the SHA1 errors.
Fourth
For the repository can't be authenticated errors, install y-ppa-manager and update the gpg authorization keys. In terminal, type:
sudo apt-get update
sudo apt-get install y-ppa-manager
Then start PPA Manager from the Unity dashboard.
heynnema
  • 73,649
