My settings, docs and such on an older 14.04 USB stick are persistent, but the 16.04 stick seems to reset with each reboot.
I made a USB stick following the directions here: https://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
and using the rufus installer.
Is there a way to configure this install so that my work stays on the stick?
Thanks!
MmmHmm
  • 123
If you want to make a Persistent USB stick try mkusb, UNetbootin or MultiBootUSB, not Rufus, they will all make persistent drives however mkusb will make persistent partitions greater than 4GB, and MultiBootUSB will allow multiple persistent O/S installs.
C.S.Cameron
  • 20,530
  • 78
  • 125
Rufus Persistent Pendrive install
That works with both BIOS and UEFI
Rufus does an OK job of installing Ubuntu Live to USB. It works with both BIOS and UEFI. It does not do Pesistent installs out of the box.
Many people prefer a Persistent pendrive that will save changes.
  • Create a Live pendrive using Rufus.
  • Boot the Rufus pendrive toram to make the drive editable, (press shift when booting, press Esc from language, press F6, press Esc, type {space}toram after "quiet splash ---", and press Enter.
  • Create a casper-rw file:
    sudo dd if=/dev/zero of=casper-rw bs=1M count=512
    sudo mkfs.ext3 -L casper-rw -F casper-rw
(where count=512 is persistence size, with max 4GB).
  • Move the new casper-rw file from home to the root of the Live Pendrive.
  • Edit /isolinux/txt.cfg, (for BIOS boot persistence) and /boot/grub/grub.cfg, (for UEFI boot persistence), add a space and the word "persistent" after "quiet splash ---".
  • Shut down and reboot the persistent drive.
*Casper-rw partitions do not work with Rufus.
C.S.Cameron
  • 20,530
  • 78
  • 125
