How can I replace ugly screensaver unlock screen in Xubuntu 11.10?
Standard xscreensaver is very ugly.
Is there any themes for unlock screen?
The closest you can come to theming is to change the colours/fonts & date-time format. Anything more will probably need to recompile xscreensaver and change the source.
For example -
can be changed to -
Using leafpad (leafpad ~/.Xresources) create/amend the file .Xresources located in the home folder.
Copy and paste the following for the first picture above:
xscreensaver.splash: false
!font settings
xscreensaver.Dialog.headingFont: --dina-bold-r---12-------
xscreensaver.Dialog.bodyFont: --dina-medium-r---12-------
xscreensaver.Dialog.labelFont: --dina-medium-r---12-------
xscreensaver.Dialog.unameFont: --dina-medium-r---12-------
xscreensaver.Dialog.buttonFont: --dina-bold-r---12-------
xscreensaver.Dialog.dateFont: --dina-medium-r---12-------
xscreensaver.passwd.passwdFont: --dina-bold-r---12-------
!general dialog box (affects main hostname, username, password text)
xscreensaver.Dialog.foreground: #ffffff
xscreensaver.Dialog.background: #111111
xscreensaver.Dialog.topShadowColor: #111111
xscreensaver.Dialog.bottomShadowColor: #111111
xscreensaver.Dialog.Button.foreground: #666666
xscreensaver.Dialog.Button.background: #ffffff
!username/password input box and date text colour
xscreensaver.Dialog.text.foreground: #666666
xscreensaver.Dialog.text.background: #ffffff
xscreensaver.Dialog.internalBorderWidth:24
xscreensaver.Dialog.borderWidth: 20
xscreensaver.Dialog.shadowThickness: 2
!timeout bar (background is actually determined by Dialog.text.background)
xscreensaver.passwd.thermometer.foreground: #ff0000
xscreensaver.passwd.thermometer.background: #000000
xscreensaver.passwd.thermometer.width: 8
!datestamp format--see the strftime(3) manual page for details
xscreensaver.dateFormat: %I:%M%P %a %b %d, %Y
Copy and paste the following for the second picture:
!font settings
xscreensaver.Dialog.foreground: #111111
xscreensaver.Dialog.background: #ffffff
xscreensaver.Dialog.Button.foreground: #ffffff
xscreensaver.Dialog.Button.background: #666666
xscreensaver.Dialog.text.foreground: #ffffff
xscreensaver.Dialog.text.background: #666666
xscreensaver.dateFormat: %I:%M%P %b %d
The run through the following steps to enable your changes:
xrdb -merge ~/.Xresources
killall xscreensaver
xscreensaver -no-splash &
If you are familiar with svg image programmes (like Inkscape), you also could modify the logo to suit your own wishes. The logo is located in usr/share/pixmaps and is called xscreensaver.svg and xscreensaver.xpm.
However, there is a remark on changing the logo. See this thread for more info
Also, there are various important restrictions regarding the xpm file. I neglected those, resulting in a complete crash of my system. I will give it a try in the future, but so far i will stick to the flaming computer logo. See here for the restrictions, which I found only afterwards: http://www.improbability.net/xss/
And here is the process you have to follow to properly hard-code the images: http://www.inductiveload.com/posts/change-the-xscreensaver-icon/ or http://web.archive.org/web/20130309211615/http://www.inductiveload.com/posts/change-the-xscreensaver-icon
By the way, I suggest to change the font to something else, as not everyone has the "dina" font. It will then revert back to its original, failsafe font. Replacing "dina" with "arial" works for example, but the Ubuntu font doesn't seem to work.
Following fossfreedom's example, I chose the following settings in a a newly created ~/.Xresources file, and I found the result quite attractive (a dark-background theme with gentle blues):
!font settings
xscreensaver.Dialog.headingFont: -*-georgia-bold-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.bodyFont: -*-georgia-medium-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.labelFont: -*-georgia-medium-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.unameFont: -*-georgia-medium-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.buttonFont: -*-georgia-bold-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.dateFont: -*-georgia-medium-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.passwd.passwdFont: -*-georgia-bold-r-*-*-18-*-*-*-*-*-*-*
xscreensaver.Dialog.foreground: #00efef
xscreensaver.Dialog.Button.foreground: #111111
xscreensaver.Dialog.Button.background: #2040e0
xscreensaver.Dialog.text.foreground: #2040e0
xscreensaver.Dialog.text.background: #efefef
xscreensaver.Dialog.internalBorderWidth:36
xscreensaver.Dialog.borderWidth: 0
xscreensaver.passwd.thermometer.foreground: #2040e0
xscreensaver.passwd.thermometer.background: #2040e0
xscreensaver.passwd.thermometer.width: 0
xscreensaver.dateFormat: %I:%M%p - %a %b %d, %Y
Also with the changes loaded with:
xrdb -merge ~/.Xresources; killall xscreensaver; xscreensaver -no-splash &
Solution with Xresources is a good one, I use it myself, but you may as well try these:
The Arch distro actually modifies the dialog to present an Arch logo. The relevant package with a link to the source repo is here: https://aur.archlinux.org/packages/xscreensaver-arch-logo
In that repository, you'll find image files of different dimensions and formats, along with a PKGBUILD file. That file describes how they go about recompiling the original xscreensaver source with the Arch imagery.
It shouldn't be too hard to implement your own version of what's in that PKGUILD file:
prepare() {
local logos_png
local logos
cd "${srcdir}"
logo-360.png)
for _pngfile in "${logos_png[@]}"; do
install -Dm0644 "${_pngfile}" "${srcdir}/${pkgname%%-*}-${pkgver}/hacks/images/${_pngfile}"
done
logos=(logo.pdf
logo-50.xpm
logo-180.xpm
logo-360.xpm
logo-big.gif)
for _file in "${logos[@]}"; do
install -Dm0644 "${_file}" "${srcdir}/${pkgname%%-*}-${pkgver}/utils/images/${_file}"
done
build() {
cd "${pkgname%%-*}-${pkgver}"
./configure
--prefix=/usr
--sysconfdir=/etc
--localstatedir=/var
--libexecdir=/usr/lib
--with-app-defaults=/usr/share/X11/app-defaults
--without-setuid-hacks
--with-pam
--with-login-manager
--with-gtk
--with-gl
--without-gle
--with-pixbuf
--with-jpeg
make
package() {
install -d "${pkgdir}/etc/pam.d"
make install_prefix="${pkgdir}" install
install -Dm0644 ../LICENSE "${pkgdir}/usr/share/licenses/${pkgname}/LICENSE"
It seems they use raw Xlib for security reasons.
