I have installed Ubuntu 16.04.1 alongside windows 10, everything works perfect unless gnu grub menu 2.0.2 takes too long to boot, there is somewhere 15-20 sec black screen till purple grub menu shows up.
It is ASUS k501ux laptop with PCIE SSD and it always boot very fast. it is loading windows in 13 sec and Ubuntu in 8 sec but that grub menu takes too long. sometimes it loads perfectly as soon as I turn it on but mostly that's not case.
Otherwise both Ubuntu and Windows load pretty quickly after I choose it from Gnu grub menu, problem is loading time of gnu grub menu itself.
To see what grub is doing while it's loading the kernel image and booting up Ubuntu you need to remove the splash screen and enable messaging. Open the terminal and use the command gksu gedit /etc/default/grub and search for this line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash vt.handoff=7 kaslr"
Change the line to look like this:
GRUB_CMDLINE_LINUX_DEFAULT="vt.handoff=7 kaslr"
Leave the other parameters alone (which probably don't look like mine). The important thing is to remove "quiet" and "splash" parameters.
Save the file and then use:
sudo update-grub
Now reboot your computer and watch for messages that pause for a long time. After getting a message that pauses for a long time you can review the log file using:
gedit /var/log/syslog
Additionally the time for all services loaded during boot can be reviewed using:
systemd-analyze blame
After getting specifics of what module(s) is/are slowing down your boot you can ask pointed question(s) about it/them
Well our problems may have been caused by something completely different but I'll tell you what I did to fix it for me anyway.
Firstly, for me it was the bios's fault, not grub.
I have a HP bios. (And ubuntu 18.04, which shouldn't be relevant)
I tried changing the boot order, I tried every boot option within reason (and that would have worked but the option I needed wasn't on the list, which was to boot straight from the "netbook hard drive".)
In the end I had to enable legacy boot for that to be an option, and then I went with the default legacy boot settings (instead of "hybrid") and lo and behold grub now pops up in about 1 second instead of 15.
Rabbit
  • 792
