I have a pc with dual-boot Ubuntu/Windows since more than 5 years. The last working configuration was : windows 10 and Ubuntu 16.04 LTS.
I install Ubuntu 16.10 on the Linux partition and have some problems:
- If I only boot on Linux, no problems, it works fine.
- If I boot windows, no problem, windows works fine.
- If I boot Linux after windows, I have a superblock error and drop to busybox.
If I restore the superblock with
fsck.ext4 -p -b 884736 -B 4096 /dev/sda5
I can boot Linux but after another boot to Windows the same problems reoccurs.
Of course I have tried solutions found:
chkdskandtestdiskwhile on windows.- I remove the extended partition and let the Linux installer recreate them.
- Create by and, the extended partion + ext4 and swap and select these partition during the install process.
The partition table (fdisk -lu):
Disk /dev/sda: 298,1 GiB, 320072933376 bytes, 625142448 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6bb7527c
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 22783999 22781952 10,9G 7 HPFS/NTFS/exFAT
/dev/sda2 * 22784000 22988799 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda3 22988800 375246847 352258048 168G 7 HPFS/NTFS/exFAT
/dev/sda4 375246848 625141759 249894912 119,2G f W95 Ext'd (LBA)
/dev/sda5 383440896 617844735 234403840 111,8G 83 Linux
/dev/sda6 617846784 625141759 7294976 3,5G 82 Linux swap / Solaris
I did some more tests without success:
- I removed the Linux extended partition
- I extended the windows partition to the full disk
- I launched a
chkdsk /F /Ron this new windows partition → after a couple of hours all is good - I reinstalled Ubuntu 16.10 and let the install program resize the disk and create the ext4 and swap part.
- I boot Linux → no problem
- I boot windows → no problem (I reach the windows menu that let me choose between Windows and Linux, I choose Windows)
- I boot Linux: same problem again (superblock error)
Update : the exact superblock error :
fsck.ext4: Superblock checksum does not match superblock while trying to open /dev/sda5
To repair it :
works fine, but after a Windows boot, the problem is there again ...
Update 2 :
From W10, I can mount the linux ext4 partition with the W10 ext2 tool. It works fine, I can see the files. But after that, same problem, when I boot on Linux: superblock errors.
Of course if I just boot W10 (no login) and reboot linux, the problem is there too.
The problem was present with W10 1511, I've upgraded to W10 1607 : same problem
I saw that I was not alone on earth with this problem, but I did not see any solution.
update2 : I removed the linux and swap partition and create a new partition from windows. Then I reinstalled Ubuntu 16.10 => same problem again
update 3: The beginning of solution
I have perhaps found a solution.
When loggued in windows :
With the command diskpart, when the linux volume is set offline
there is no more problem when I boot linux.
I now have to find how to set the volume offline automaticaly (regedit ?)
