Since you have little detail about your setup I will make some assumptions.
1) you are not using the unity desktop, but something like Gnome Classic. I use flashback/fallback with Metacity, No Compiz compositor or editor to get the 'workspaces' in a row along the bottom panel.
2) maybe you only have 4 GiB for RAM?
To overcome some of the same difficulties I first increased my HP ProBook 440 G1 Laptop to 8 GiB of RAM by adding a 4 GiB stick of the exact same RAM. My CPU (i3) already has 4 cores @ 2.4 GHz., so I was good there.
I find with Modern OS's and App's 4 GiB's of RAM is not an acceptable amount of RAM.
My desktops boxes have 16 and 32 GiB of RAM as you can never have enough RAM
I used System Profiler and Benchmark available in the Ubuntu-Gnome 14.04.5 Software Center to find "How my Setup was doing?" When Version 16x first came out I found too many applications were Missing or not Working in the Software Center (perhaps this has been fixed by now), so I opted-out and reinstalled "Ubuntu-Gnome" 14.04 (not just Ubuntu, but the one with the Gnome included). I have my particular likes!
I used System Monitor to see what was running that I did not need or want.
I answered a post (Why is zero swap being used on my setup?), where there is a discussion about Memory use and I had some Ideas to look at. One of the thins I do is covered in How do I add/remove the "hidden" startup applications?.
One thing I learned is that Firefox uses Ram and Cache as one monolithic Block and Google-chrome or Opera Browser setup multiple Blocks. Not sure what is better as many debate this?, But I have found, both have a greedy approach to keep stuff in Cache and some RAM just in case you might ever use it again... in effect never releasing the former so other operations/app's might use it!!!
In Summery... Control your startup App's
Some are not visible so you will want to edit "someDesktopApp.desktop" (note you need to be in a 'root' file mode to see the *.desktop extension) and change them from
NoDisplay=false/NoDisplay=true
(link above). You do not need yet another App to control startups as once visible you can check them Off with the menu
Applications >> System Tools >> Preferences >> Startup Applications
Don't go crazy and turn too much off at once, as you may kill something you need or an indicator you want!! do some research on what does what.
Get rid of things like "animations" and other "Eye Candy" The only effective way I have found is to learn and understand "dconf Editor" (A pain in the a*$ and needs much improvement). Try ctrl+F to find stuff.
Try my way to clean the Cache. Some say NOT!!!, but it works for me when things get slow and I don't have to reboot
sudo sync && sudo sysctl -w vm.drop_caches=3
I set it up as a menu item with a file and the link to:
#/bin/bash
[locate in /usr/local/bin]
Setup a Menu Item
[~/.local/share/applications/menulibre-clean-ubuntu-cache.desktop]
(I like menulibre better then alacarte)
[Desktop Entry]
Version=1.0
Type=Application
Name=Clean Ubuntu Cache
Comment=To free pagecache, dentries and inodes:
Icon=aptdaemon-update-cache
Exec=gksudo /usr/local/bin/clean_cache
NoDisplay=false
Categories=menulibre-favorites1
StartupNotify=true
Terminal=false
Actions=NewShortcut;
[Desktop Action NewShortcut]
Name=clean 3
Exec=sudo sync && sudo sysctl -w vm.drop_caches=3
#OnlyShowIn=Unity
In the line above... Categories=menulibre-favorites1 ... is for my personal Menu category so you might want to set it to something different
Hope this helps. Something to think about anyway
James Niland
