Ubuntu is unable to play DVDs.
I used regionset to change the region.
libdvdcss (the newest version) is installed.
I enabled the option "No DVD menus" in VLC, and it doesn't work.
What should I do?
On Ubuntu 16.04 type in the terminal
sudo apt-get install libdvd-pkg
After installing libdvd-pkg you must run this command
sudo dpkg-reconfigure libdvd-pkg
This should allow DVD Playback
If you're still having trouble, most likely the region of your device is not set properly (or at all). Install regionset by typing
sudo apt-get install regionset
and then run
regionset
You have to install few codecs required specifically to play DVDs comfortably. These are:
libdvdcss2: to recognize DVDlibdvdread4: to read DVDlibdvdnav4: to navigate DVDStep #1 Install libdvdcss2
Since medibuntu is no longer available, you have to install libdvdcss2 manually from VLC repositories :
wget http://download.videolan.org/pub/debian/stable/libdvdcss2_1.2.13-0_i386.deb
sudo dpkg -i libdvdcss2_1.2.13-0_i386.deb
Step #2 Install libdvdread4 and libdvdnav4
Open terminal (Ctrl + Alt + T) and run following command:
sudo apt-get install libdvdread4 libdvdnav4
