I would like to watch a DVD. However, I have run into difficulties. Here is what I have done so far.
  1. started by following these instructions
    Specifically, here are the steps identified in that web page that I have followed
    sudo apt install libdvd-pkg
    pressed "ok" or similar to various routine sounding prompts
    sudo dpkg-reconfigure libdvd-pkg
    Result:
    Step 1 does not seem to have worked as I don't think VLC media player is on my computer. At least I don't see it when I click on the icon with the 9 dots in the bottom left of my screen (the tool the brings up the list of programs). Also, when I insert the DVD and then I right click the DVD looking icon (the icon that comes up on the desktop) the closest appropriate program that I can find is "video player" but when I select that, that gives an error message.
  2. Next, I followed some instructions on How to play DVDs in Ubuntu 16.04?.
    Regarding the first answer listed there, I seem to have already done something similar to the first part of that answer (the first 2 parts of that answer). So, I skipped those steps. I did do the steps related to the region code. Next, I started to try the second answer listed.
    I tried this command,
    wget http://download.videolan.org/pub/debian/stable/libdvdcss2_1.2.13-0_i386.deb
    sudo dpkg -i libdvdcss2_1.2.13-0_i386.deb
    But, that doesn't seem to have worked. A lot of the response that got generated by terminal, says wget: unable to resolve host address
    At the end, terminal says
    downloaded: 1 files, 43k in 0.1s
    It doesn't sound like it downloaded much in the end, so I am thinking that the steps in answer 2 have not been working so far.
muru
  • 207,228
libdvd-pkg only installs the libdvdcss files required for decrypting the discs.
Also run the following to install the applications files needed for browsing the discs:
sudo apt install libdvdnav4 libdvdread4
Then you should just be able to install the VLC Player:
sudo apt install vlc
I like to install everything that VLC has, so I run this:
sudo apt install vlc*
You can also install the ubuntu-restricted-extras that gives you more encoders and applications for playing media:
sudo apt install ubuntu-restricted-extras
Terrance
  • 43,712
