Usually, laptop screens are dim set to the lowest level of brightness when the charger is not present, and brighten up to the max level if the charger is present/connected. However, on my Dell Inspiron 7559 Skylake laptop, this does not happen. My laptop is always on 100% brightness. How can I retrieve this "feature"?
Asked
Active
Viewed 61 times
Introduction
The script below is modified version of my previous scripts, written in python and using dbus exclusively for polling ac_adapter presence and setting the screen brightness.
Usage
Usage is simple: call from command line as
python ./brightness_control.py
The script defaults to 100% brightness on AC , 10% on battery. Users can use -a and -b to set their desired brightness levels on ac and battery respectively.
AS given by -h option:
$ ./brightness_control.py -h
usage: brightness_control.py [-h] [-a ADAPTER] [-b BATTERY]
Simple brightness control for laptops,
depending on presense of AC power supply
optional arguments:
-h, --help show this help message and exit
-a ADAPTER, --adapter ADAPTER
brightness on ac
-b BATTERY, --battery BATTERY
brightness on battery
For example, one can do any of the following:
# set non default for brightness on ac
$ ./brightness_control.py -a 80
# set non-default value for brightness on battery
$ ./brightness_control.py -b 20
# set non-default values for both
$ ./brightness_control.py -a 80 -b 20
Source
Also available on GitHub
#!/usr/bin/env python
Author: Serg Kolo <1047481448@qq.com>
Date: Nov 3rd , 2016
Purpose:Brightness control depending on
presence of ac adapter
Written for: http://askubuntu.com/q/844193/295286
import argparse
import dbus
import time
import sys
def get_dbus_property(bus_type, obj, path, iface, prop):
""" utility:reads properties defined on specific dbus interface"""
if bus_type == "session":
bus = dbus.SessionBus()
if bus_type == "system":
bus = dbus.SystemBus()
proxy = bus.get_object(obj, path)
aux = 'org.freedesktop.DBus.Properties'
props_iface = dbus.Interface(proxy, aux)
props = props_iface.Get(iface, prop)
return props
def get_dbus_method(bus_type, obj, path, interface, method, arg):
""" utility: executes dbus method on specific interface"""
method = proxy.get_dbus_method(method, interface)
if arg:
return method(arg)
else:
return method()
def on_ac_power():
adapter = get_adapter_path()
call = ['system','org.freedesktop.UPower',adapter,
'org.freedesktop.UPower.Device','Online'
if get_dbus_property(*call): return True
def get_adapter_path():
""" Finds dbus path of the ac adapter device """
call = ['system', 'org.freedesktop.UPower',
'/org/freedesktop/UPower','org.freedesktop.UPower',
'EnumerateDevices',None
devices = get_dbus_method(*call)
for dev in devices:
call = ['system','org.freedesktop.UPower',dev,
'org.freedesktop.UPower.Device','Type'
if get_dbus_property(*call) == 1:
return dev
def set_brightness(*args):
call = ['session','org.gnome.SettingsDaemon.Power', '/org/gnome/SettingsDaemon/Power',
'org.gnome.SettingsDaemon.Power.Screen', 'SetPercentage', args[-1]
def parse_args():
info = """
arg_parser = argparse.ArgumentParser(
description=info,
formatter_class=argparse.RawTextHelpFormatter)
arg_parser.add_argument(
'-a','--adapter',action='store',
type=int, help='brightness on ac',
default=100,
required=False)
'-b','--battery',action='store',
type=int, help='brightness on battery',
default=10,
required=False)
return arg_parser.parse_args()
def main():
args = parse_args()
while True:
if on_ac_power():
set_brightness(args.adapter)
while on_ac_power():
time.sleep(1)
else:
set_brightness(args.battery)
while not on_ac_power():
time.sleep(1)
if __name__ == "__main__": main()
Sergiy Kolodyazhnyy
- 107,582
