Installed Ubuntu 16.04.01 side by side with Win10. It's there but grub does not work. Grub2 is on sda6 with ubuntu. Should it not be on sda1 with EFI file or on sda3 with win10?
It is a HP laptop (I gather that HP is a particular problem. Had I known this before I bought it ...) with UEFI boot. I have edited the EFI file changing the boot order with efibootmgr, but nothing changed.
Current state of EFI file after edits ...
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 0001,3001,3001,0002,0000,2001,2002,2004
Boot0000* Notebook Hard Drive - HGST HTS545050A7E680
Boot0001* Windows Boot Manager
Boot0002* ubuntu
Boot2001* EFI USB Device
Boot2002* EFI DVD/CDROM
Boot3001* Internal Hard Disk or Solid State Disk
extract from mtab ...
/dev/sda1 /boot/efi vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro 0 0
/dev/sda3 /media/carol/Windows fuseblk rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
From boot repair ([http://paste2.org/MWC9zIc2 ]) it is a NTFS drive for windows
HarveyP
  • 33
I have workarounds.
Method 1
1. press < esc > during boot
2. press F9
3. select ubuntu from menu
4. Here is the Grub ...
But this is not ideal.
Method 2
Set next EFI boot in .profile as my Ubuntu drive
echo "rootpassword" | sudo -S efibootmgr -n 0002 #my ubuntu address for next boot
Unfortunately sudo does not work in .profile - substitute YOUR root password ...
So every time I log into Ubuntu, my next boot is the grub boot, however this does not help me when I have logged into Win10 ...
HarveyP
  • 33
Install Boot Repair on Ubuntu and run it with recommended options. It should reinstall and configure grub with proper settings and fix your problem.
sudo add-apt-repository ppa:yannubuntu/boot-repair sudo apt-get update sudo apt-get install -y boot-repair && boot-repair
I was reading through [Installing Ubuntu Alongside a Pre-Installed Windows with UEFI ] and got to the part near the bottom to go to Win10 setup using < shift >Restart - nice to know ...
In BIOS setup, Boot-Order I found 2 entries against the OS line when I pressed < enter > on that line (flagged with a little triangle!), one was Win10, the other ubuntu.
I used F5/F6 to change the order so that ubuntu was at the top and selected - it seemed not to be enough to have it either selected or at the top, it must be both - and left that screen using < F10 > as < esc > just leaves without changing anything.
I also made sure that legacy support was disabled, as it was before I started messing about, before I left using < F10 > again.
And it now works. Grub has Windows as default and a whole lot of entries that will only confuse, but I can edit that ...
Thanks for the help above!
HarveyP
  • 33
