Before that happened always when i connected modem to USB port ethernet connection was applied automatically. Now after i plug modem to USB system recognize it as a CD/DVD device, file manger opens that CD root location, and there is no available connection in the Network Manager. And when i try :
usb_modeswitch
it says:
usb_modeswitch -v 12d1 -p 1f01 -W -J
Take all parameters from the command line
 * usb_modeswitch: handle USB devices with multiple modes
 * Version 2.2.5 (C) Josua Dietze 2015
 * Based on libusb1/libusbx
 ! PLEASE REPORT NEW CONFIGURATIONS !
DefaultVendor=  0x12d1
DefaultProduct= 0x1f01
HuaweiNewMode=1
NeedResponse=0
Look for default devices ...
  found USB ID 12d1:1f01
   vendor ID matched
   product ID matched
  found USB ID 1d6b:0002
  found USB ID 04d9:a02e
  found USB ID 1d6b:0001
  found USB ID 0fce:719b
  found USB ID 09da:c10a
 Found devices in default mode (1)
Access device 007 on bus 002
libusb: error [_get_usbfs_fd] libusb couldn't open USB device /dev/bus/usb/002/007: Permission denied
libusb: error [_get_usbfs_fd] libusb requires write access to USB device nodes.
Error opening the device. Abort
How can i fix this? P.S. Don't know if it is related but it happened in a short time after i was doing some changes related to create .ISO image with k3b and brasero.
tricky
  • 41
I had the same problem with Huawei E1750 on Ubuntu 16.10 (worked fine on Ubuntu 16.04). I solved it by installing the latest version of usb-modeswitch and usb-modeswitch-data from Debian unstable. I also had to install the libjim0.76 package (from the Ubuntu archive).
The issue will be fixed via bug #1639607.
