First of all I m a newbie to ubuntu and recently installed 16.10. Then when i tried to connect to the internet my usb dongle doesn't show up.
I tried everything, googled many times. I tried adding a new connection in the regular way by going to wifi sign in top right corner and etc etc... But nothing worked.
In my dongle there is a folder named Linux and there are few files like install , 7zr , Mobile partner.dat and also a readme.txt. I ve done every step of the instructions there is in the readme.
It says login as root (sudo) and type tar (some 4 letters) Linux_install.tar.bz2.
When i execute this code terminal shows there is no files or events(something similar to that.).
Then I looked to see if my device is recognized by the OS using lsusb And it shows that USB Modem Huawei Technology.inc is recognized as a mass storage device.
My Dongle: Huawei Mobile Broadband E303
output of lsusb:
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 10f1:1a4f Importek
Bus 001 Device 006: ID 0930:0220 Toshiba Corp.
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 12d1:14fe Huawei Technologies Co., Ltd. Modem (Mass Storage Mode)
Bus 003 Device 003: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 003 Device 002: ID 09da:000a A4Tech Co., Ltd. Optical Mouse Opto 510D /
OP-620D
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
muru
  • 207,228
ThePilot
  • 23
This is probably caused by a bug in the usb-modeswitch package. A fixed version of usb-modeswitch is currently available in my PPA.
Open a terminal window and run these commands:
sudo add-apt-repository ppa:gunnarhj/misc
sudo apt update
sudo apt install usb-modeswitch
Then reboot. Now - hopefully - all you need to do is inserting the dongle, and it should be detected automatically.
