I have created two types of users, one is admin and another is a standard user.
ctrl+H is the shortcut to see hidden files in most of the linux file managers.
I want to disable that option for standard user. When a standard user tries to unhide files then the system won't do anything, just disable the hide and unhide options.
My primary goal is when any standard user press ctrl+H then system not show hidden files to standard user.
Secondary goal is there is no any other option to see hidden files for standard user.
I only concentrate to only revoke from seeing hidden files because making hidden files are easy and time saving as compare to make separate permission for each folder. Managing separate permissions for each folder is time consuming and sophisticated task and Also we need root privilege to manage permission or edit permission, I want to avoid many times calling for Root. Also when managing permission many times we confuse between system files/folder also there is probability to making any silly mistake during manage special permissions as per each folder/file.
In simple words I want revoke access of files which names are starting with . dot
