On my laptop i'm running kodi connected to my tv with HDMI.
After suspending and resuming it my audio doesn't come out of the TV anymore but out of the laptops speakers. I've read multiple posts on how to set the default audio output after wakeup but it doesn't seem to work. Anybody knows how to fix this?
Fixing PulseAudio switching from TV to Laptop on Suspend
This "undocumented feature" appeared with Ubuntu 16.04 and new version of PulseAudio 8.
Create a new file /lib/systemd/system-sleep/tv-sound and copy in:
#!/bin/sh
case $1/$2 in pre/) echo "Going to $2..." # Place your pre suspend commands here, or exit 0 # if no pre suspend action required sleep 1 ;; post/) echo "Waking up from $2..." # Place your post suspend (resume) commands here, or exit 0 # if no post suspend action required sleep 2 export PULSE_RUNTIME_PATH="/run/user/1000/pulse/" sudo -u rick -E pacmd set-card-profile 0 output:hdmi-stereo ;; esac
NOTE: replace user name rick (third line from the bottom) with your user name.
Then mark it executable with the command:
sudo chmod +x /lib/systemd/system-sleep/tv-sound
An additional step might be required if output:hdmi-stereo (the device for most people) is different on your system.
I have the same problem. I tried tv-sound in /lib/systemd/system-sleep solution and that didn't work for me. I tried pacmd set-card-profile 0 output:hdmi-stereo from the user command line, and that didn't work for me.
What did work strangely enough, was opening sound settings under the speaker control. I didn't change anything, just the act of opening the settings caused the HDMI sound to recover. It isn't automatic, but it doesn't force me to reboot.
I did a pacmd dump before and after opening the settings window and there was no difference in the output.
As a side note, the 1000 in /run/user/1000/pulse is the user ID and needs to match the user name. When I was trying the solution I was logged into my wife's account which has a user ID of 1001.
kmiller
