I have been trying to resolve an issue here where my upgrade failed.
I just want to know it is possible and what anybody recommends. I have an idea. I would like to download ISO image from here, and burn it into cd with these instructions.
I have some questions. Can I then copy all my files into an external USB or cd for backup, or would I be able to get all my data files restored?
If I can copy data to CD, how should I do it? Then how should I begin the upgrade or fresh clean process after I burned the ISO image into DVD
TheOdd
  • 3,012
Once you've booted off the live media you have created you should be able to mount a target USB device as well as your source partition(s) and copy the data you require over to the target device (your forum post indicates that you already have a backup).
After you have copied all your required data you can simply install as normal.
Elder Geek
  • 36,752
