64
I got a strange error after upgrading Ubuntu 16.04 to 16.10.
The Software Updater suggests a partial update:
Could not install 'systemd-shim'
The upgrade will continue but the 'systemd-shim' package may not be in a working state. Please consider submitting a bug report about it.
subprocess installed post-removal script returned error exit status 2
sudo apt-get update finishes without any error.
sudo apt-get remove outputs this
The following packages will be REMOVED:
  systemd-shim
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 71.7 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 1451244 files and directories currently installed.)
Removing systemd-shim (9-1bzr4ubuntu1) ...
Removing 'diversion of /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service to /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.systemd by systemd-shim'
dpkg-divert: error: rename involves overwriting '/usr/share/dbus-1/system-services/org.freedesktop.systemd1.service' with
  different file '/usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.systemd', not allowed
dpkg: error processing package systemd-shim (--remove):
 systemd-shim
Please help me to fix this error. Thank you.
karel
  • 122,292
  • 133
  • 301
  • 332
zappee
  • 997
  1. Using the terminal, rename /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service to /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.bak:
    sudo mv /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.bak
  2. Proceed to run sudo apt upgrade again.
Hopefully no more systemd-shim errors should appear.
Rename the file back to what it was if you have any issues.
terdon
  • 104,119
CrazyLemon
  • 1,286
