I try to install gcc4.9 on Ubuntu 14.04 and run:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
with following error:
W: Failed to fetch http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu/dists/trusty/main/binary-amd64/Packages  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old  ones used instead
I type http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu/dists/trusty/main/binary-amd64/Packages into the browser getting 'not found' reply.
try to install anymore:
sudo apt-get install gcc-4.9
with following:
 gcc-4.9:i386 : Depends: cpp-4.9:i386 (= 4.9.4-2ubuntu1~14.04.1) but it is not going to be installed
                Depends: gcc-4.9-base:i386 (= 4.9.4-2ubuntu1~14.04.1) but it is not going to be installed
                Depends: binutils:i386 (>= 2.24) but it is not going to be installed
                Depends: libgcc-4.9-dev:i386 (= 4.9.4-2ubuntu1~14.04.1) but it is not going to be installed
                Depends: libc6:i386 (>= 2.11) but it is not going to be installed
                Depends: libcloog-isl4:i386 (>= 0.17) but it is not going to be installed
                Depends: libgmp10:i386 but it is not installable
                Depends: libisl15:i386 (>= 0.15) but it is not going to be installed
                Depends: libmpc3:i386 but it is not installable
                Depends: libmpfr4:i386 (>= 3.1.3) but it is not going to be installed
                Depends: zlib1g:i386 (>= 1:1.1.4) but it is not installable
                Recommends: libc6-dev:i386 (>= 2.13-0ubuntu6) but it is not going to be installed
Trouble downloading packages list due to a "Hash sum mismatch" error --this doesn't work to me.
Any suggestions will be great to me:-)
if you trim the url back to the folder like this
then it works in the browser and you can see that there is a gzip and bzip2 compressed copy of the Packages file. You could download this file and put it in /var/cache/apt/archives/list or /var/cache/apt/archives/ it might skip the failing step.
update: looking at the ppa's page i can see there is another link that will work better , try this
sudo add-apt-repository ppa:ubuntu-toolchain-r/ppa
Amias
  • 5,359
