I'd like to mount an ext4 partition with subfolders for multiple users
/data
  user1/
  user2/
just like /home. Thus I copied the fstab entry of the /home mouting,
UUID=...   /data    ext4    defaults    0    2
manually created the mount point
sudo mkdir /data
and created subfolders with the appropriate rights:
sudo mkdir /data/user1 && chown user1:user1 /data/user1
sudo mkdir /data/user2 && chown user2:user2 /data/user2
Though this allows the users to create files in their subfolder, they are not able to move them to trash.
I manually created the lost+found folder with no luck.
# ls -al /data/ | grep lost
drwx------  2 root        root        4096 Okt 15 11:55 lost+found
What do I need to change to enable the trash?
the trash directory needs to be named in this format to make this work: .Trash-$UID Allow for 'Move to trash' instead of 'permanently delete' for mounted partition?
According to this archlinux post referring to the FreeDesktop Trash Specification we can use trash folders for each user, that are located in the top folder
/data
  .Trash-<user1.uid>
  .Trash-<user2.uid>
and that are owned by the respective user.
chown user1:user1 /data/.Trash-<user1.uid>
chown user2:user2 /data/.Trash-<user2.uid>
After this modification users are able to create files, to delete files to the trash and to recover them.
Update: You have to re-log to make this work.
the correct format for the said trash directory is
.Trash-$UID
mkdir -p .Trash-$UID/{expunged,files,info} chown $UID:$GID -Rv .Trash-$UID chmod 750 -Rv .Trash-$UID
The above works for me in ubuntu, arch, and fedora references:
https://wiki.archlinux.org/title/Trash_management
https://bbs.archlinux.org/viewtopic.php?id=207042
-1
I created a script named mktrash.sh to mkdir the trash-folder.
#!/bin/bash
if [ "$1" = "" ]; then echo "Parameter: <mount path> - the top directory" exit fi
TRASH=$1/.Trash UTRASH=$TRASH/$UID
echo Creating Trash Directory: $UTRASH echo Ctrl-C to Cancel, Enter to Continue echo You will need to enter your SUDO password for creating $TRASH read VAR
sudo mkdir -v $TRASH sudo chmod -v 1777 $TRASH mkdir -v $UTRASH chmod -v 700 $UTRASH
Would be nice to have this automated for any mounts.
Once the .Trash dir exists, new users should be added automatically as Trash is world writeable.
JPT
  • 369
