I want to create some control groups using cgroup.
So far I have done the following:
I installed some packages:
sudo apt-get install cgroup-bin cgroup-lite cgroup-tools cgroupfs-mount libcgroup1Then I created the
/etc/cgconfig.conffile with the following content:mount { cpuset = /cgroup/cpuset; cpu = /cgroup/cpu; cpuacct = /cgroup/cpuacct; memory = /cgroup/memory; devices = /cgroup/devices; freezer = /cgroup/freezer; net_cls = /cgroup/net_cls; ns = /cgroup/ns; blkio = /cgroup/blkio; } group limitcpu{ cpu { cpu.shares = 400; } } group limitmem{ memory { memory.limit_in_bytes = 512m; } } group limitio{ blkio { blkio.throttle.read_bps_device = "252:0 2097152"; } } group browsers{ cpu { cpu.shares = 200; } memory { memory.limit_in_bytes = 128m; } }according to the guide here, assuming, that the config file resides at the same location and uses the same syntax on Ubuntu, as it uses on CentOS.
Then according to that guide I need to start the
cgconfig service. I tried with:sudo service cgconfig restartBut, oh no! A file is missing!:
Failed to restart cgconfig.service: Unit cgconfig.service not found.After some wondering and searching around, I tried:
● cgconfig.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead)
So it seems I am simply not having any cgconfig service on my system!
I searched for it using:
sudo aptitude search cgconfig
However, no cgconfig is to be found.
How can I install cgconfig on my Ubuntu 16.04?
