I am going through https://gist.github.com/juanje/9861623. I am trying to limit my Chromes memory usage on my Ubuntu 18.04. It appears my system don't have any of the mentioned commands/files here. What would be a proper way to configure cgroup on my Ubuntu 18.04?
Asked
Active
Viewed 5,057 times
First, you should ensure that you have kernel 4.5 or higher. Actually, most things will work with 4.11 or higher. $ uname -a
This is because you most likely have cgroup v2 , not v1, which has different configuration. Most of the links for ubuntu 16.04 and others, refer to v1. Don't get confused.
If your run "mount -t cgroup" , you should see a list of cgroups, all under /sys/fs/cgroup .
Now, the configurations starts with : $ cp /usr/share/doc/cgroup-tools/examples/cgred.conf /etc/
Then, the rest are very similar to : Install cgconfig in Ubuntu 16.04
All info about the new case (18.04) be found in : https://www.paranoids.at/cgroup-ubuntu-18-04-howto/
The test in my case, showed my new /sys/fs/cgroup/memory/browsers/ and tasks.
Good luck.
MiGrieves
- 67
