how do I install tightvnc on Ubuntu? Have tried to download the rpm and run rpm -ivh packagename but I get this error because of a missing dependency:
    /bin/sh is needed by tightvnc-java-1.3.9-3.noarch
Can't I just install through the commandline?
ada dudu
tightvnc-java should be available in trusty's multiverse repositories:
apt-cache policy tightvnc-java
tightvnc-java:
  Installed: (none)
  Candidate: 1.2.7-8
  Version table:
     1.2.7-8 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/multiverse amd64 Packages
To install the java client using the commandline, you would do this:
apt-get install tightvnc-java
There is also a X client:
apt-get install xtightvncviewer
And if you need the server:
apt-get install tightvncserver
Perhaps you might want to look at ssvnc as well - the comment within the package says it is an "Enhanced TightVNC viewer with SSL/SSH tunnel helper".
Anwar
  • 77,855
Ubuntu is based on debian and it works with debian packages, not rpms. Moreover, you don't need to download the package file manually. You need to use this command in a terminal only.
sudo apt-get install tightvncserver
If this command complains with "no such package found", you need to enable universe repository. Check this question for how to do that How do I enable the "Universe" repository?
Anwar
  • 77,855
