I did try the both the solutions given here, however it fails with the following error.
    m = alsaaudio.Mixer('PCM')
alsaaudio.ALSAAudioError: Unable to find mixer control 'PCM',0
I'm assuming that my mixer control is not PCM. When I change the volume on my laptop, I use alsamixer, and where I select the sound card to be HDA Intel PCH. I'm using the Realtek ALC3235.
Here is the result from my amixer
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
How should I fix this?
After the change from CL.
This is what my amixer looks like.. maybe this is of any help
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 87
  Mono: Playback 75 [86%] [-9.00dB] [on]
Simple mixer control 'Headphone',0
  Playback channels: Front Left - Front Right
  Mono:
  Front Left: Playback [off]
  Front Right: Playback [off]
Simple mixer control 'Headphone+LO',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB]
  Front Right: Playback 0 [0%] [-65.25dB]
Simple mixer control 'Speaker',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Line Out',0
  Mono:
  Front Left: Playback [on]
  Front Right: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 63
  Front Left: Capture 52 [83%] [21.75dB] [on]
  Front Right: Capture 52 [83%] [21.75dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Speaker Only' 'Line Out+Speaker'
  Item0: 'Line Out+Speaker'
Simple mixer control 'Dock Mic',0
  Capabilities: cswitch cswitch-joined cswitch-exclusive
  Capture exclusive group: 0
  Capture channels: Mono
  Mono: Capture [off]
Simple mixer control 'Dock Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Headset Mic',0
  Mono: Capture [off]
Simple mixer control 'Headset Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Internal Mic',0
  Mono: Capture [on]
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
tandem
  • 121
alsaaudio goes to the default sound card. By default, this is the first card, which in your case appears to be the HDMI output.
To make the second card the default, add the following to /etc/asound.conf or your ~/.asoundrc:
defaults.ctl.card 1
defaults.pcm.card 1
CL.
  • 1,795
From your amixer result, this could work:
m = alsaaudio.Mixer(1,'PCM')
The "1" is for the 2nd sound device (HDA Intel).
muru
  • 207,228
laugeo
  • 2,880
  • 14
