I've been working to install Ubuntu 16.04 on my Acer Aspire R 14 laptop which came pre-installed with Windows 10 and a UEFI Firmware system.
I've looked through nearly every thread and none of them seem to have any effect.
I've partitioned my hard drive and have now installed (and uninstalled) Ubuntu about a dozen times varying the mode in which I installed it (Secure Boot enabled vs. Disabled) and where I attempted to install the Grub Bootloader when given the option to do "something else" when installing ubuntu (/dev/sda, /dev/sda1 (efi partition), /dev/sda6 (linux partition)).
I've attempted to mount and install grub via:
$ sudo mount /dev/sda6 /mnt
$ sudo mount /dev/sda1 /mnt/boot/efi  # and /mnt/boot
$ for i in /dev /dev/pts /proc /sys; do sudo mount -B $i /mnt$i; done
$ sudo cp /etc/resolv.conf /mnt/etc/ # for network compatibility
$ modprobe efivars
$ sudo chroot /mnt
# apt-get install --reinstall grub-efi-amd64
I've also tried using the automated boot-repair tool.
These runs completed successfully with the given output: http://paste2.org/9Hzds0J5 http://paste2.org/KJt55GbI
I even followed up afterward in entering the given windows command: bcdedit /set {bootmgr} path \EFI\ubuntu\shimx64.efi
My issue is that no matter what I do, the ubuntu boot partition is not recognized by windows or the Firmware. For example, my boot order is:
  1. HDD: WDC WD10SPCX-21KHST0
  2. Windows Boot Manager
  3. USB HDD: KinstonDataTraveler 3.0 (My Ubuntu USB stick)
  4. USB FDD:
  5. Network Boot-IPV4:
  6. USB CDROM:
  7. Network Boot-IPV6:
My boot system is the InsydeH2O Setup Utility.
My disk partitions are:
  • /dev/sda1 EFI System
  • /dev/sda2 Microsoft Reserved
  • /dev/sda3 Microsoft Basic Data
  • /dev/sda4 Windows Recovery
  • /dev/sda5 Linux Swap
  • /dev/sda6 Linux Filesystem
Ideally I'd like to get my computer booting to grub since I've never had issues booting windows from grub before. Any help would be greatly appreciated.
P.S. Thanks to all the members of the askubuntu forums for the answers they've posted to similar questions that have gotten me this far. I've read most of them, but was not allowed to cite them due to the limited number of urls that I could post.
Jordan
Two things. Make sure you are in UEFI mode in your Live Session. You can test this by running this from the terminal:
$ dmesg | egrep "EFI v"
The output will be blank if you are in Legacy.
Also, be sure to include update-grub in your grub repair steps. The steps below should resolve your issue. The bold characters in the steps are unique for you based on the info in your question.
 1:$ sudo mount /dev/sda6 /mnt
 2:$ for i in /sys /proc /run /dev; do sudo mount --bind "$i" "/mnt/$i"; done
 3:$ sudo mount /dev/sda1 /mnt/boot/efi
 5:$ sudo chroot /mnt
 6:# grub-install /dev/sda
 7:# update-grub
 8:# exit
 9:$ for i in /sys /proc /run /dev; do sudo umount "/mnt/$i"; done
10:$ sudo umount /mnt/boot/efi
11:$ exit
L. D. James
  • 25,444
You installed Ubuntu in legacy-mode on the drive sda where Windows8 is installed in UEFI-mode. Boot-repair reinstalled Grub for UEFI-mode. Some machines need more workaround, it depends on the UEFI-firmware of your computer. The first thing to try is to follow this advice from your boot-info-summary:
If your computer reboots directly into Windows, try to change the boot order
in your BIOS.If your BIOS does not allow to change the boot order, change
the default boot entry of the Windows bootloader. For example you can boot
into Windows, then type the following command in an admin command prompt:
mook765
  • 18,644
