I'm trying to find the location of the config file for gsettings, specifically referencing the number of workspaces. I know the commands:
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ vsize 3
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ hsize 3
but where is the file which these commands change? I did a search using
find / -name gsettings > ~/gsettings_file.txt
From this I found /usr/share/GConf/gsettings, but after searching through the files, I still could not locate the workspaces config settings.
Zanna
  • 72,312
By default the user settings are stored in ~/.config/dconf/user. This is a binary file so you can't edit it manually.
See Shouldn't dconf-editor and gsettings access the same database? for some more information about what files are used by gsettings and dconf.
