When using natilus as root, open in terminal used to work as using with any user. However, when I press open in terminal when using nautilus as root now, it does nothing.
How to solve it?
The error:
GLib-GObject-CRITICAL **: g_object_set_data: assertion 'G_IS_OBJECT (object)' failed
Vitor Abella
  • 8,015
  • 16
  • 63
  • 115
Putting aside any possible damage you've done via sudo nautilus command you could just install & use the nautilus extension nautilus-admin, requires restarting nautilus after install
sudo apt-get install nautilus-admin
It provides
* Open as Administrator: opens a folder in a new Nautilus window running with administrator (root) privileges. * Edit as Administrator: opens a file in a Gedit window running with administrator (root) privileges.
Does so thru a policykit policy.
doug
  • 17,212
I know this thread is more than 8 years old at this point but I was looking for a way to access Nautilus on Ubuntu 24.04.2 LTS with root access yesterday and found a clever way using the following simple command in terminal:
nautilus admin:/
This launches nautilus with the prompt to log in using your password (sudo) and gives root access to nautilus.
Shout out to Raymond KIMATHI at codegeek for the solution I found. Full link to his page: Open nautilus as root – Ubuntu 24.04
He also shows the code needed to add a desktop shortcut in his article however does not elaborate on how to do that.
