I am currently trying to rebuild my GRUB after reinstalling Windows 7 and this guide says I need to perform an extra step if I have separate boot partition.
I tried to look it up but from what I could see I can only find info on how to see the boot partition in a proper install and not while running the Live CD.
My sda1 partition has the boot asterisk when I run fdisk -l says it has id 7
and is a HPFS/NTFS/exFAT and shows 100Mib (23 Mib) used in GParted.
Is this the boot partition I am meant to mount? Or, is this only for Windows 7? Is there some kind of Ubuntu boot partition I do not have?
sda2 is my Windows 7 partition
sda3 is the extended partition that contains:
sda5(main Linux partition)sda6(Linux swap partition)
I do not know if I ever had an sda4 partition.
I tried to rebuild the GRUB using the same guide before without mounting a separate boot partition so I am not sure as I did not think I had one and it booted to Windows 7 as always. I am not sure if that is relevant in anyway.
