I have seen carefully many suggestions online, yet not able to overcome the issue. I was able to connect yesterday and use my bluetooth speaker but not today.
from bluetoothctl
~$ bluetoothctl
[NEW] Controller 0C:D2:92:78:36:FA billy-Lenovo-G500s [default]
[NEW] Device FC:A8:9A:A6:8F:B2 JBL Flip 3
[bluetooth]# devices
[bluetooth]# connect FC:A8:9A:A6:8F:B2
Attempting to connect to FC:A8:9A:A6:8F:B2
Failed to connect: org.bluez.Error.Failed
[bluetooth]#
I am running ubuntu 16.04 with gnome and my bluez Version: 5.37-0ubuntu5 some good idea?
/B
I did what Bradyn Claycomb suggested but it was not enough so I improved it as follows:
sudo apt install pulseaudio-module-bluetooth
pulseaudio -k
pulseaudio --start
Then I can connect to my Bluetooth headphone from Ubuntu 16.04
Fthi.a.Abadi
  • 779
I had a similar issue with my Jaybird X2 earbuds and this is what solved it for me:
Run
sudo apt-get install pulseaudio-module-bluetooth
Then run
sudo apt-get install ofono
Followed by a reboot.
If I understand correctly, there is a known bug with bluetooth in 16.04 and this worked in my case. Let us know if this works.
B-Dawg
  • 355
I found that the Bluetooth redirection of sound to the audio device (Score K1-MINI) is reliable only if sound from Rythmbox music player software is already going to the laptop (Dell Vostro 3550) speakers BEFORE making the Bluetooth connection to the Bluetooth speakers. Then it takes a few seconds to change over in mid stream. Some how, (without an audio stream), the Bluetooth connection just seems to stay connected to the old output destination, even when you use the “Test Sound” button in sound settings.
wwmbes
  • 101
