How to install pgAdmin 4 in desktop mode? The documentation only details server mode.
For pgAdmin 4 v4.21 on Ubuntu, according to the download page:
Install dependencies, create a virtual environment, download, install & configure
Using Python2.x
sudo apt-get install virtualenv python-pip libpq-dev python-dev
cd
virtualenv pgadmin4
cd pgadmin4
source bin/activate
pip install https://ftp.postgresql.org/pub/pgadmin/pgadmin4/v4.21/pip/pgadmin4-4.21-py2.py3-none-any.whl
Using Python3.6 (Preferred to avoid encoding related issues)
sudo apt-get install virtualenv python3-pip libpq-dev python3-dev
cd
virtualenv -p python3 pgadmin4
cd pgadmin4
source bin/activate
pip3 install https://ftp.postgresql.org/pub/pgadmin/pgadmin4/v4.21/pip/pgadmin4-4.21-py2.py3-none-any.whl
Configure
Override default paths and set it to single-user mode in the local configuration file:
nano lib/python2.7/site-packages/pgadmin4/config_local.py
For Python3.x:
nano lib/python3.6/site-packages/pgadmin4/config_local.py
Write:
import os
DATA_DIR = os.path.realpath(os.path.expanduser(u'~/.pgadmin/'))
LOG_FILE = os.path.join(DATA_DIR, 'pgadmin4.log')
SQLITE_PATH = os.path.join(DATA_DIR, 'pgadmin4.db')
SESSION_DB_PATH = os.path.join(DATA_DIR, 'sessions')
STORAGE_DIR = os.path.join(DATA_DIR, 'storage')
SERVER_MODE = False
Run
python lib/python2.7/site-packages/pgadmin4/pgAdmin4.py
For Python3.x:
python3 lib/python3.6/site-packages/pgadmin4/pgAdmin4.py
Access
Access at http://localhost:5050
Exit
Exit with Ctrl-C
Run again
cd ~/pgadmin4
source bin/activate
For Python3.6
#!/bin/bash
cd ~/pgadmin4
source bin/activate
Make a shortcut
touch ~/pgadmin4/pgadmin4
chmod +x ~/pgadmin4/pgadmin4
nano ~/pgadmin4/pgadmin4
Write:
#!/bin/bash
cd ~/pgadmin4
source bin/activate
For Python3.6
#!/bin/bash
cd ~/pgadmin4
source bin/activate
Now you can just run it with a simpler command:
~/pgadmin4/pgadmin4
Python3 users
Replace [x] in Python3.6 with your respective version.
Conflict with pgAdmin 3 configuration
pgAdmin 4 will not start in the environment where pgAdmin 3 was previously installed and used because of incompatible configuration in the .pgadmin directory. The simplest solution is to either clear that directory or tweak config_local.py to point to a clean new .pgadmin4 directory.
- 9,244
Other option is to use docker and a docker image provided by thaJeztah - https://github.com/thaJeztah/pgadmin4-docker
$ docker run --rm -p 5050:5050 thajeztah/pgadmin4
Then to access a PostgreSQL DB instance from within pgadmin4 you should use the IP of the host instead of localhost and 127.0.0.1 since Docker will map those to the container itself.
The IP of a dockerised DB instance could be found with 2 steps:
find the container ID of your db with:
docker psinspect the container_name to find its ip with:
docker inspect <ID from previous step>
you are looking for something like "IPAddress": "172.18.0.3"
- 9,244
- 631
On Ubuntu 16.04 you can install pgadmin4 with
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ $(lsb_release -cs)-pgdg main" >> /etc/apt/sources.list.d/pgdg.list'
sudo apt install wget ca-certificates
wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add
sudo apt update
sudo apt install pgadmin4
I have tested this on 16.04.
- 6,519
- 1,248
- 3
- 14
- 19
Finally, pgAdmin team created an apt package for pgAdmin4
It is supported on:
- Debian 9 (Stretch), 10 (Buster)
- Ubuntu 16.04 (Xenial), 18.04 (Bionic), 19.10 (Eoan), 20.04 (Focal)
Now to install it you have to setup the the pgAdmin 4 offical repository, then you can install it
Setup the repository
Install the public key for the repository (if not done previously)
curl https://www.pgadmin.org/static/packages_pgadmin_org.pub | sudo apt-key add
Create the repository configuration file:
sudo sh -c 'echo "deb https://ftp.postgresql.org/pub/pgadmin/pgadmin4/apt/$(lsb_release -cs) pgadmin4 main" > /etc/apt/sources.list.d/pgadmin4.list && apt update'
Install pgAdmin4
You can install both Desktop and Web modes:
For Desktop only:
sudo apt install pgadmin4-desktop
For Web only:
sudo apt install pgadmin4-web
- 137
