I have a new Lenovo Ideapad 500S with a fresh Ubuntu 16.04.1 running on it. Unfortunately, the brightness up/down keys don't work. (They work fine in Windows.)
Running acpi_listen shows me generated events for volume up/down keys, but not for brightness up/down. Running xev also did not give me any output for the brightness up/down keys.
After editing the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub several times with options like acpi_backlight=vendor,video.use_native_backlight=1, acpi_osi=Linux and acpi_osi=, I can confirm that this changes the soft links in /sys/class/backlight/ and I currently only have intel_backlight there.
Running echo <NUM> | sudo tee /sys/class/backlight/intel_backlight/brightness works fine and changes the brightness, and so does changing it from Settings > Brightness and Lock.
Nothing inside Ubuntu seems to be able to detect these keys, so I'm not sure making any changes in the grub config will matter at all.
Please let me know if someone knows how to fix this and also if any additional information will be useful in debugging this issue.
Update:
Adding acpi_osi=Linux acpi_backlight=intel_backlight to the line in grub seems to make the brightness down key generate something in xev (though nothing in acpi_listen yet). The output is:
KeyPress event, serial 37, synthetic NO, window 0x3c00001,
    root 0xd3, subw 0x0, time 391361, (728,884), root:(793,936),
    state 0x0, keycode 120 (keysym 0x0, NoSymbol), same_screen YES,
    XLookupString gives 0 bytes:
    XmbLookupString gives 0 bytes:
    XFilterEvent returns: False
KeyRelease event, serial 37, synthetic NO, window 0x3c00001,
    root 0xd3, subw 0x0, time 391368, (728,884), root:(793,936),
Additional outputs:
$ lspci -nnk | grep -iA2 vga
00:02.0 VGA compatible controller [0300]: Intel Corporation Sky Lake Integrated Graphics [8086:1916] (rev 07)
    Subsystem: Lenovo Skylake Integrated Graphics [17aa:3828]
    Kernel driver in use: i915_bpo
I finally solved this using a couple of workarounds.
The first step was making the keys detectable. I had a laptop of a similar model (Lenovo Z400) and I looked at what keycodes were generated for it. Based on that, I put this in my /etc/rc.local/:
setkeycodes e054 225 # Brightness up -> brightness up
setkeycodes e04c 224 # Brightness down -> brightness down
The second step was making the keys change the brightness. I first noticed that running xdotool key 232 and xdotool key 233 increased and decreased the brightness perfectly (including the change notification in Unity). Then I tried two things to get the brightness to work.
First, I noticed that xev now showed me the events XF86MonBrightnessUp and XF86MonBrightnessDown for the two keys, which means everything was working fine at the X level. So I simply used Ubuntu's shortcut manager and registered the two keys (which were read as their XF86 equivalents) to the xdotool commands. This worked great!
However, some weeks later, due to some packages/drivers I changed, xev stopped reporting the XF86 events and so the above method did not work. However, acpi_listen showed that video/brightnessdown and video/brightnessup events were being generated, so then, after some googling, I put the following in a new file, /etc/acpi/events/ideapad-monitor-brightness-up:
# same event as reported by acpi_listen
event=video/brightnessup BRTUP 00000086 00000000 K
action=su vivek -c "export DISPLAY=:0.0; xdotool getactivewindow && xdotool key 233 2>&1 > /tmp/log"
# The redirection into /tmp/log probably doesn't make any difference
and also an equivalent ideapad-monitor-brightness-down file with xdotool key 232 and that solved the problem. Haven't had any problems since. :)
I haven't had problems with brightness keys since 2012 with my older laptop (Toshiba Satellite Core 2 Duo) under Ubuntu 14.04 but it appears many users have. The most popular solution is to create the file by typing:
sudo touch /usr/share/X11/xorg.conf.d/20-intel.conf
then edit the file using:
gksu gedit /usr/share/X11/xorg.conf.d/20-intel.conf
then populate the file with:
Section "Device"
        Identifier  "card0"
        Driver      "intel"
        Option      "Backlight"  "intel_backlight"
        BusID       "PCI:0:2:0"
EndSection
Save and reboot.
Note the BusID should match the output of:
Also replace intel_backlight above with what appears in lspci command if different.
Another option to try is change grub command line with acpi_backlight=vendor.
Update
I just stumbled across this Ubuntu webpage on brightness keys: https://wiki.ubuntu.com/Kernel/Debugging/Backlight
When I upgrade to Ubuntu 16.04 it brought with it Kernel 16.04 and I had all types of problems with suspend/resume, thin fonts, black screens instead of wallpaper, higher than normal CPU usage and hotter than normal temperatures. I wrote up many of the steps I took in this answer: Ubuntu 15.10: Various "types" of freezes and now unexpected shutdown which solved most my problems on an Intel Ivy Bridge platform and it may very well help your Sky Lake platform.
