When I try to open another partition in my PC, it shows this error message:
error message
How can I fix this error??
(Ubuntu 16.04)
edwinksl
  • 24,109
Windows saves hibernation data in any NTFS drives you mount, even if you haven't hibernated Windows. The recommendation to fix the issue is to make sure you fully shut down your computer after using Windows, but that doesn't generally work.
Instead, use ntfsfix.
In case it isn't installed:
sudo apt-get install ntfs-3g
Then:
sudo ntfsfix /dev/sda3
That should let you mount it.
TheWanderer
  • 19,525
  • 52
  • 65
