I have the red error icon on the headings, and I followed many advice from the forum but none of them worked for me. I use Ubuntu in Hungarian but maybe you can read out the important stuff from the error message. I typed in sudo apt-get install -f and this is the result:
$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
kde-config-telepathy-accounts
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 362 not upgraded.
2 not fully installed or removed.
Need to get 0 B/137 kB of archives.
After this operation, 825 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 213142 files and directories currently installed.)
Preparing to unpack .../kde-config-telepathy- accounts_4%3a15.12.3-0ubuntu1_amd64.deb ...
Unpacking kde-config-telepathy-accounts (4:15.12.3-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+16.04.20160126-0ubuntu1
Processing triggers for libc-bin (2.23-0ubuntu3) ...
EDIT!:
~$ sudo apt-get autoremove kde-config-telepathy-accounts
Package 'kde-config-telepathy-accounts' is not installed, so not removed
You might want to run 'apt-get -f install' to correct these:
kde-telepathy-minimal : Depends: kde-config-telepathy-accounts (>= 15.04.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
hamana@hamana-AO756:~$ sudo apt-get autoclean
hamana@hamana-AO756:~$ sudo apt-get update
Get:1 http://hu.archive.ubuntu.com/ubuntu xenial InRelease [247 kB]
Hit:2 http://archive.canonical.com/ubuntu xenial InRelease
Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [94.5 kB]
Get:4 http://hu.archive.ubuntu.com/ubuntu xenial-updates InRelease [95.7 kB]
Fetched 437 kB in 1s (338 kB/s)
hamana@hamana-AO756:~$ sudo apt-get --reinstall kde-config-telepathy-accounts
E: Command line option --reinstall is not understood in combination with the other options
hamana@hamana-AO756:~$ sudo apt-get install --reinstall kde-config-telepathy-accounts
Preparing to unpack .../kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb ...
