Fresh install of lubuntu xenial
Was having issues where print service wasn't found (this prompt). Cups wasn't installed for some reason (maybe another streamlining choice lubuntu made?). Tried to install cups sudo apt-get install cups --install-suggests It was doing stuff for hours and slowing down the system. Trying to look up why it was taking so long (probably suggests was a bad choice?), I closed the terminal window by accident aborting the process. Now runit and git-daemon-run are causing issues. I can't complete anything in synaptic or apt without it being angry that they are broken.
I've tried quite a few things, but here's probably the most relevant thing to paste:
$ sudo dpkg --configure -a
Setting up runit (2.1.2-3ubuntu1) ...
start: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
dpkg: error processing package runit (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of git-daemon-run:
git-daemon-run depends on runit; however:
Package runit is not configured yet.
dpkg: error processing package git-daemon-run (--configure):
dependency problems - leaving unconfigured
runit
git-daemon-run
Please help!
EDIT: @jokerdino was correct in marking this as a duplicate. Trying the advice of @minigeek gave the Upstart error mentioned in the dupe link. Removing runit seems to have worked fine:
sudo dpkg -r --force-all runit
sudo apt-get remove --purge git-daemon-run
