I have a computer that refuses to boot due to problems with NVIDIA drivers. I have tried everything I can think of to fix the drivers, but it always boots into low-graphics mode.
Therefore, I decided to try and run boot-repair from a USB drive (Ubuntu GNOME) to see if that might fix it, and after I select "Try without installing" it hangs on a black screen forever. If I select "check disk for defects" it reboots the computer. The strange part is, if I insert the same USB into my laptop, it works perfectly. Secure boot is off, booting from USB is enabled in BIOs, I've tried multiple ports, different flash drives, resetting the BIOs to defaults, dialing back my overclock... Nothing works.
Here are my system specs:
Asrock z77 Pro3
i5 3570k
32GB DDR3
PNY GTX 1060 6GB
256GB lite-on ssd
