I was wondering if somebody already programmed a GUI for the wonderful TLP power-management application?
From https://github.com/linrunner/TLP/issues/129#issuecomment-98478154, the main author of TLP has recommended TLPUI, which is a GTK GUI written in Python. Do note that this is beta software, so bugs are to be expected.
You first would need to get version 0.9-1 of tlp via the TLP PPA since the version of tlp in the offical repos is only 0.8-1 and the GUI app needs at least version 0.9:
sudo add-apt-repository ppa:linrunner/tlp
sudo apt-get update
sudo apt-get install tlp
Then, according to the installation instructions at TLPUI's GitHub repo:
Download a zip file of the repo at https://github.com/d4nj1/TLPUI/archive/master.zip
Extract the zip file and run
python3 tlpui.py
Alternatively, you can just use git to clone the repo:
git clone https://github.com/d4nj1/TLPUI.git
cd TLPUI
python3 tlpui.py
Then do git pull or git fetch followed by git merge periodically to update your local copy of the repo.
- 24,109
Old question, but since it still shows up pretty high in search results:
There's also Slimbook Battery, a GUI that integrates with TLP and other services to manage power in a more guided way than TLP alone (or TLPUI). It probably gives you less fine-grained control than those other options, but (for me at least) it helps cut through the wall of options.
Install with
sudo add-apt-repository ppa:slimbook/slimbook
sudo apt install slimbookbattery
Once started, Slimbook will also prompt you with other tools you can install to better manage performance/power for your machine.
- 111
