I just bought a Dell Inspiron 15 5000 laptop with a AMD A10-8700P CPU. I removed Windows 10 and installed Ubuntu 16.04.
When plugged in, at random times, the battery icon will appear showing that the charge is below 100% and that the battery is charging. This happens even when the laptop has been plugged in for quite a while and it's still plugged in.
When the battery is being used, it drains very rapidly (less than one hour) even if I'm just using Google Chrome. Sometimes when using the battery, the laptop will simply shutdown even if it hasn't reached a low percentage.
After unplugging the laptop, it will often sow ridiculous times until full discharge. Example: I just unplugged it after being fully charged, and it shows 17hs left.
If I check the energy status, I see that the battery capacity is at 78.1%. Is this normal for a brand new laptop? Is my battery dying? How can I check for this? Could this be an issue with Ubuntu's kernel that could be solved by upgrading it?
The output of upower -i /org/freedesktop/UPower/devices/battery_BAT1 when the battery is being used is:
  native-path:          BAT1
  vendor:               LGC
  model:                DELL 991XP62D62D
  serial:               9DFC
  power supply:         yes
  updated:              lun 20 jun 2016 14:32:41 ART (97 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               discharging
    warning-level:       none
    energy:              281,644 Wh
    energy-empty:        0 Wh
    energy-full:         323,824 Wh
    energy-full-design:  414,4 Wh
    energy-rate:         25,6188 W
    voltage:             15,731 V
    time to empty:       11,0 hours
    percentage:          86%
    capacity:            78,1429%
    technology:          lithium-ion
    icon-name:          'battery-full-symbolic'
  History (charge):
    1466443961  86,000  discharging
  History (rate):
    1466443961  25,619  discharging
and when it is plugged in:
  native-path:          BAT1
  vendor:               LGC
  serial:               9DFC
  power supply:         yes
  updated:              lun 20 jun 2016 14:36:59 ART (51 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               charging
    warning-level:       none
    energy:              263,884 Wh
    energy-empty:        0 Wh
    energy-rate:         23,1768 W
    voltage:             15,515 V
    time to full:        2,6 hours
    percentage:          81%
    capacity:            78,1429%
    icon-name:          'battery-full-charging-symbolic'
  History (charge):
    1466444201  81,000  discharging
  History (rate):
    1466444218  23,177  charging
    1466444201  26,699  discharging
The command cat /sys/class/power_supply/BAT1/ueventPOWER_SUPPLY_NAME=BAT1 gives:
POWER_SUPPLY_STATUS=Discharging
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=0
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=14800000
POWER_SUPPLY_VOLTAGE_NOW=15510000
POWER_SUPPLY_CURRENT_NOW=1782000
POWER_SUPPLY_CHARGE_FULL_DESIGN=28000000
POWER_SUPPLY_CHARGE_FULL=21880000
POWER_SUPPLY_CHARGE_NOW=18300000
POWER_SUPPLY_CAPACITY=83
POWER_SUPPLY_CAPACITY_LEVEL=Normal
POWER_SUPPLY_MODEL_NAME=DELL 991XP62D62D
POWER_SUPPLY_MANUFACTURER=LGC
POWER_SUPPLY_SERIAL_NUMBER=9DFC
