Recentley i installed another linux distro on another partition on my SSD disk. During the instalation i reinstalled grub on the computer, and ever since my Ubuntu OS has been very slow to boot up. This has never been an issue before , and im very qurious to find out what is causing it.
Before this, the boot has been very fast. As soon as i log in the ssd seems to work fine, no change i behaviour.
I reinstalled grub on my ubuntu distro and now grub displayes Ubuntu and an old linux mint distro i have deleted to make room for a new one.
I followwed another solution changing the UUID in /etc/fstab, by baking up the original and creating a new one.
I ran:
sudo vim /etc/fstab
This file was empty so I entered the UUID for the swap memory partition. Now I'm stuck in tty1.
I've tried to reinstall Ubuntu desktop, ctrl + alt +f7, tried to run sudo /etc/init.d/gdm restart nothing works. I've checked a lot of similar issues "stuck in tty1" etc. nothing is working.
Trying to fix the /etc/fstab.bak file by running:
sudo cp /etc/fstab.bak /etc/fstab
is not working beacause i only get "read-only" in the tty1 output. Please help, i dont want to reinstall my OS.
Update: I tried following this answer, but every terminal command in the answer gives output like: this doesnt exist, no such directory etc.
I've looked at several similar tty1 issues/post and i'm still stuck.
Well you didn't have to follow the steps from my answer exactly. But here is a detailed way to recover your system from the slow boot:
  1. Undo the GRUB modification:
    • Open GRUB:
      sudo nano /etc/default/grub
    • Change this line:
      GRUB_CMDLINE_LINUX_DEFAULT=
      to
      GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
    • Now save the file and exit: Ctrl + O, then Enter and Ctrl + X.
    • Update GRUB:
      sudo grub-mkconfig -o /boot/grub/grub.cfg
  2. Now, open a terminal and type:
    sudo blkid
    and note down the UUID of your swap partition. The output will have a line that looks something like:
    /dev/sda6: UUID="727cac18-044b-4504-87f1-a5aefa774bda" TYPE="swap" PARTUUID="8rof66hg-12"
ITS BETTER TO COPY THE UUID PART FROM THE ABOVE OUTPUT, i.e., 727cac18-044b-4504-87f1-a5aefa774bda
  1. BACKUP YOUR EXISTING FSTAB FIRST BY TYPING THE FOLLOWING COMMAND:
    sudo cp /etc/fstab /etc/fstab.bak
    • 3a. Next, open your etc/fstab file:
      sudo nano /etc/fstab
  2. Repalce the UUID of the existing swap partition with the one that you copied earlier, i.e., change
    UUID=whateverishere none        swap        defaults    0 0
    to
    UUID=727cac18-044b-4504-87f1-a5aefa774bda   none        swap        defaults    0 0
  3. Now save the file and exit: Ctrl + O, then Enter and Ctrl + X.
  4. Reboot.
Raphael
  • 8,135
This answer gave me the idea to boot from usb disk image. From there none of the provided terminal codes worked expect mounting the partition i couldnt access.
Then i accessed my partition from:
/media
found the fstab file and followed the provided answer above.
