I have Lenovo M30-70 i3-4005U 4GB RAM HD4400 120GB Patriot SSD I want to install Ubuntu 16.04.1 How to partition my SSD(Swap,root...)? Thanks
I recently got a 128GB SanDisk USB Fit flash drive for the exact same purpose. I gave 3GB to swap and the rest went to root. Even though my laptop, comes with 8GB my ram usage is sitting at about 3GB right now but this is most likely because I'm running Google Chrome with several tabs open. I would definitely recommend a minimum of 2GB of swap for your setup though.
At first glance this question seems like a duplicate of how-to-use-manual-partitioning-during-installation. Please look at this question and accepted answer for the what you need to do.
Set your swap size to 4GB and hopefully it will be seldom used because swap on a SSD will wear it down faster.
After installation look at SSD life extending techniques such as TRIM and log file writes. In summary:
Add noatime,nodiratime to your ssd drives or partitions, after ext4
UUID=bef10b86-494d-41c6-aa46-af72cfba90fd / ext4 discard,noatime,nodiratime,errors=remount-ro 0 1
UUID is your actual device not the one in the example. For more information read: what-ssd-optimization-are-needed-on-latest-ubuntu-version
Don't worry about these technical details right away. You have lots of time to optimize your SSD life extension. We are talking of extending from 7 years to 10 years probably. Your mileage may vary.
- 105,762
You haven't mentioned any specific requirements that are out of the ordinary, so I would recommend going with the installer defaults.
The installer defaults are carefully chosen to be the best compromise that would satisfy the most situations. The reason you alter defaults is when you have specific requirements, which you don't appear to have.
- 37,804
