When I plug external speakers into the docking station for Thinkpad T420s i get no sound (internal speakers mute).
P.S. I know the solution but it seems to be ok post problem specific solution in form of question and answer.
The solution is to add line
options snd-hda-intel model=thinkpad
to the /etc/modprobe.d/alsa-base.conf.
After that you have to reload alsa:
killall pulseaudio
sudo alsa force-reload
pulseaudio -D
This can be applicable on other thinkpad laptops.
You can also try different models (see HdaIntelSoundHowto at help.ubuntu.com).
If this method doesn't help you can to try to debug hda-intel using HDA Analyzer. For example for my laptop I could use:
/usr/local/bin/hda-verb /dev/snd/hwC0D0 0x01c SET_PIN_WIDGET_CONTROL 0x40
to enable sound on external speakers. But it is not very good solution since you have to do it manually each time you plug external speakers.
hda-verb program can be downloaded from ftp://ftp.suse.com/pub/people/tiwai/misc/hda-verb-0.3.tar.gz.
I encountered a similar problem.
The correct option to pass to snd-hda-intel is tp410, as referenced here in the Linux kernel.
A file under /etc/modprobe.d/ ending in .conf should contain
options snd-hda-intel model=tp410
(don't forget to check for existing entries)
This worked for me with a Lenovo 90W ultra dock and X240:
options snd-hda-intel model=lenovo-dock
Seth
  • 59,332
akahunahi
  • 155
